Replacing Leaf Spring - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Replacing Leaf Spring
    May 2007
    Edmonton
    17 Focus RS
    Default Replacing Leaf Spring
    Im in the process of taking the leafspring out of my silverado 1500 (never played around with suspension repairs before).
    I have a jack stand on either side of the axle, is this enough support for when the leaf is completely out? It seems to me that the area would almost completely fall/flop down on the one part where there is no suspension.
    Is there anything else you'd recommend doing?
    Any advice/tips would be really appreciated.
    May 2007
    Calgary, Ab
    KTM200XCW/S13/4WD
    What year is the truck? Are you just replacing one leaf or both?
    If it were just one leaf, I'd put one stand under the axle near the leaf, remove the u-bolts, drop the rear then the front... if its an older truck, hit it with some penetrating oil a few hours/days beforehand, and hope to god the bushings aren't seized onto the bolts. An impact gun helps, too...
    May 2007
    Edmonton
    17 Focus RS
    hahahaha..
    Thanks Abeo. Its a 2000 Chevy, and only one leaf (driver side if it matters)
    Ive been religious with the WD-40, and im pretty sure the bushing is seized onto the front bolt.
    Them bolts are tight!!!
    Bringing out the impact gun tomorrow morning.
    2017 FERD Focus RS: @780_rs
    FERD Bro-Deal Specialist
    Sponsored by:
    That Fog Light Guy: Use promo code "780rs" for 15% off store-wide
    May 2007
    Calgary, Ab
    KTM200XCW/S13/4WD
    3 foot breaker bar from princess auto helps, too
    get the torches ready...
    This works much better than WD-40.
    click for larger version
    Dec 2004
    63 cadillac
    You should use the jack stands under the frame. Then use a floor jack to support the axel when you remove the leaf.
    May 2007
    Calgary, Ab
    KTM200XCW/S13/4WD
    Yeah, thats what you should do... apparently I wasn't thinking when I posted
    Duplex
    Ignore List
    If you can't get those bolts to budge, try using a blow torch.
    Let them heat and cool a few times while doused with the penetrating lube, that action helps draw it into the threads.
    Also, WD-40 is not a penetrating lube. Use something like FiveFreshFish posted, PD Blaster, or something similar.
    I'd be lying if I said I didn't disagree.
  1. DIY Leaf Spring Brackets ?
    By J NRG in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 09-12-2009, 02:31 PM
  2. WTB: Air Canada Maple Leaf Lounge passes
    By anythingcanada in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-30-2006, 02:20 PM
  3. Civic SI + Leaf Blower Dyno
    By hampstor in forum Cars, Bikes, Machines
    Latest Threads: 01-15-2006, 10:26 AM
  4. FS: Add-a-leaf kit by "Pro Comp", Ordered 2 by msitake
    By GTi-RS in forum Automotive Parts [Suspension/Handling]
    Latest Threads: 05-18-2005, 02:30 PM
  5. italian (flat leaf) parsley
    By robgordon in forum Food and Dining
    Latest Threads: 01-28-2005, 09:44 PM
