Excessive Shifting - Frequent Chail Derailment? - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Excessive Shifting - Frequent Chail Derailment?
    Jul 2008
    Canuckistan
    Exploded.
    Default Excessive Shifting - Frequent Chail Derailment?
    Hey everyone!
    I noticed that my chain keeps derailing everytime I shift and I was just wondering if it's caused by excessive shifting? I oil it up regularly and maybe there's an adjustment that I need to make in order for this to be resolved?
    The benefit of masks is not known at this time. But we do know it is some non-trivial amount more than zero.
    We also know that the cost of mask use is, essentially, zero.
    So the cost:benefit of mask use is approaching infinity. I'll take that every time. And every time I see someone without a mask, I think they are stupid.
    Nov 2006
    Tighten the chain?
    Feb 2003
    my bike
    What do you mean by derailing? is it coming right off the front or rear cogs? Or is ghost shifting between gears on its own?
    Jul 2008
    Canuckistan
    Exploded.
    It's a little bit of both actually. It comes off of the rear cogs and on 6, it ghost shifts and automatically goes to 7 (the smallest gear.)
    Oh yeah, which is high and low gear? Is the high gear the small one or vice versa?
    Aug 2003
    If the teeth on the gear isn't worn, have you tried adjusting the derailleur
    Feb 2003
    my bike
    think of it as a car.
    high gear = faster
    You have 3 potential problems
    1. Limit screw adjustments will solve the chain coming off the cassette (cogs).
    2. Cable indexing (tension) should eliminate the ghost shifting.
    3. A bent rear derailleur hanger.
    This link should solve your problems if it's the first 2, but only if you're somewhat mechanically inclined or have at least an hour to do it by trial and error. You shouldn't have to worry about #3 unless you've crashed, dropped the bike, or had some other impact to the rear derailleur.
    http://www.parktool.com/repair/readhowto.asp?id=64
    Jul 2008
    Canuckistan
    Exploded.
    high gear = faster
    Thanks!
    Feb 2005
    Canada
    Can also be a worn chain, dirty chain or a chain that has a kink or is damaged.
  1. CPS and excessive force, again
    By vadeit in forum Society / Law / Current Events / Politics
    Latest Threads: 04-12-2008, 10:22 AM
  2. excessive speeding? only in retarded countries
    By bart in forum Society / Law / Current Events / Politics
    Latest Threads: 12-15-2007, 10:09 AM
  3. Replies: 38
    Latest Threads: 03-11-2006, 07:50 PM
  4. Excessive noise question.
    By DannyO in forum Society / Law / Current Events / Politics
    Latest Threads: 01-06-2006, 11:17 PM
  5. excessive exhaust fumes
    By Kentish in forum Mechanical
    Latest Threads: 10-25-2005, 01:55 AM
