Installing Slate Tiles on Deck - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Installing Slate Tiles on Deck
    Feb 2006
    Calgary,Alberta Canada
    Default Installing Slate Tiles on Deck
    Im thinking about installing slate tiles on my deck. The deck right now has plywood on it. I heard that tiles outdoors in Calgary is a bad idea because of the high heat and extreme cold.
    Anyone with experience with this?
    Feb 2006
    something like this.. probably not in calgary
    Feb 2006
    Default try it again
    Feb 2008
    I installed slate tiles on my brothers deck. They have gone through 2 full winters now and only minor problems.
    Here is what I did:
    You need to make sure that the deck is built strongly and had a thick plywood top. I used 2 x 10's on 16" centers for the subframe. For the top I first layed down a layer of 3/4" plywood and on top of that layed 5/8" one side good plywood. I put it down perpendicular to the first layer with the good side up.
    From there i put down a layer of Schluter Ditra
    http://www.schluter.com/6_1_ditra.aspx
    you can get it a Tierra Sol or special order from HD or Rona. What the Ditra does is decouple the two surfaces (wood and tile) and let them expand and contract at different rates.
    Once the Ditra is down you can lay your tile as you normally would. Seal the tile with a really good penetrating tile sealer and then grout. I would keep the grout spaces as small as possible.
    The only problems that have been encountered so far are to do with the grout and the tile. Because of the nature of slate it tends to flake a bit. In a couple of small areas the grout has cracked a bit.
    Here is a pic of the finished deck.
    Before grouting.
    Sep 2007
    A vehicle or two
    ^^^ That looks awesome.
    Feb 2008
    Thanks.
    It was a lot of work but I think it worked out.
    Thanks for posting your method.
    I worked on a property a long time ago and their deck with slate tile was flaking like crazy. It didn't look good.
    Make sure you seal those things good and if you can maybe level it at an angle so the water doesn't pool up anywhere. I think this was the cause of the major flaking of the tile on property I saw. But obviously each tile could have areas that cause water to pool on the tile.
    Can you reseal the tile every year or is it a one time deal and you risk sealing in too much dirt over the years that it would look bad?
  1. FS: Dufferin Elite Series Slate Pool Table 8' with Light
    By RawB8figure in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-14-2009, 02:38 PM
  2. WTB: Someone to Install Slate Pool Table
    By Gorilla in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-25-2008, 07:35 PM
  3. FS: 2005 Slate Gray Honda Pilot EX
    By YamaLube in forum Trucks, SUVs, Vans, Trailers
    Latest Threads: 03-08-2008, 12:43 AM
  4. FS: LIKE NEW ** Slate Pool Table ** CHEAP *SOLD*
    By hingkit in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 10-18-2007, 12:05 AM
