Water Softener Advice - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: Water Softener Advice
    Feb 2004
    Calgary/ AB
    MiniCooperS
    Default Water Softener Advice
    Thinking of getting a water softener for my house since my company can get me deal at Trail Appliance.
    Just got few questions for those who have experiences or knowledge with it
    how can you tell if the plumbing is compatiable for it or not?
    is it hard to try installing it yourself?
    Thanks for advance!
    S.E. (not the drrty south)
    Natural gas, and natural gas accessories
    Default Re: Water Softener Advice
    Any water softener is "compatible" with any household. There's better ways to do it, but at the very least you can hook it between your mainline, and hotwater tank.
    It's never hard to try anything.
    The AHS system is quite good.
    You'll need to rent a crimping tool to connect the water lines unless you've got copper pipes.
    Installation is pretty straightforward. Not a bad first plumbing project.
    Jul 2002
    Cowtown
    08 VQ35HR
    I installed one this year. It came with the bypass valve which basically taps inline with the water line. Our house is newer so it uses PEX pipes which are very easy to work with. If you live in an older house, you might be running copper which migth require more skills to work with. With PEX, all you need are crimps and a crimper. Alternatively, you can use a product call sharkbite which is a toolless connector for PEX. With copper, you will need some kind of soldering and sweating skills. If you have PEX, I say go DIY but if not, I would pay $300 to get a plumber in to do it.
    Soldering copper lines isn't hard at all, just make sure you put plenty of solder on, and around the joint.
  1. WTB: Water Chiller/ from aquarium, water filter system anything you got!
    By thetransporter in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-12-2009, 01:42 AM
  2. Redline water wetter turns water black
    By Cooked Rice in forum Mechanical
    Latest Threads: 07-26-2009, 02:24 AM
  3. For Free! 2 bags of water softener salt
    By 78si in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 07-20-2009, 08:28 PM
  4. Replies: 4
    Latest Threads: 10-16-2008, 09:41 PM
  5. A good water softener
    By riceboi in forum General
    Latest Threads: 11-04-2007, 09:09 AM
