Living on acerage - Beyond.ca - Car Forums
Results 1 to 18 of 18
Thread: Living on acerage
    Feb 2006
    Calgary,Alberta Canada
    Default Living on acerage
    So I moved to an acerage and wanted to see how many other people on here live on one too. And if you had any tips.
    i.e. What type of riding lawnmower to get
    How to shovel the long drive way
    Water issues
    Apr 2005
    for the drive way get a plow on a quad or get a small tractor
    or if you have an old 4x4 get a plow for it.
    for a mower if it is a really big lawn remeber nothing runs like a deer...
    so when are you building the 1/4 mile track?
    May 2005
    Mountains/Calgary
    Das Fahrenheit
    You can get mowers that have switchable decks for grass/removing snow so that you only need one unit instead of two.
    Walker mowers makes them, here's an idea of what I'm talking about http://images.google.ca/images?hl=en...-8&sa=N&tab=wi
    There are TONS of attachments for them too.
    Originally posted by 89coupe
    I do get great service there, especially when I mention my name, haha.
    Jun 2003
    Calgary/Victoria
    Fat Boy riding a Fat Boy
    I had a John Deere 318. Both the 48" mower and the snowblower attachments. That took care of 2 acres and a pretty long driveway. Took almost 2 hours to mow the entire thing.
    The two main things to look into is water (well, co-op, city?) and sewer (septic).
    You'd probably end up with a field septic system. Have it checked and pumped once a year and its pretty maintenance free.
    Well water around Calgary sucks. If you have the funds, invest in a reverse osmosis system ($6-7k). Otherwise, count on hot water tanks lasting only 3-5 years.
    I loved acreage living.
    6.7 CUMMINS, E50 AMG
    Where did you move? How much did it set you back?
    Man i would love to live on an acerage
    Jan 2006
    Walker mowers makes them, here's an idea of what I'm talking about http://images.google.ca/images?hl=en...a=N&tab=wi
    Walker is EXCELLENT, but very pricey. A decent 20hp mower will set you back $20k.
    I agree with the suggestion, but I think for a value based option I'd check into a small John Deere ride on mower, as with the attachments needed they'd still come up to around half the price of the base cost of a walker itself.
    For a professional (lawn) cut, and for how incredibly reliable they are if you have the bucks, sure get a walker but if your minding your dollars, then I'd suggest weighing other options.
    Toro, John Deere, and Cub Cadet all have a variety of mowers with excellent options towards accessories.
    Jan 2007
    Alberta
    Acreage living ftw
    Buy a gas powered snow blower for plowing snow. I bought a decent one at home depot for 1000 on sale.
    For lawn tractor, try to find an "older" (mid 90s) John Deere - the new ones are crap. I mean, they're okay if you don't mind replacing parts like spindles and shit every few months. They just don't seem to be able to take the abuse - seems you've got to drop a lot of money (e.g., 8-10k) for a solid, reliable unit these days.
    The older ones however are awesome. I've got a 95 JD GT275. 48'' deck...it's an unstoppable beast. The transmission had almost no oil in it for the last 5yrs and it ran weekly without any hiccups (I'm surprised it hadn't seized up). My driveline belt looked like this:
    and hadn't been changed in 15yrs, and it ran flawlessly. It's so good I've dumped about 600 into it this year refreshing it up to make certain it lasts another 15.
    Oct 2008
    GrandForks BC
    Audi 5000 QT
    when i lived on a farm years back in sask.. we had a honda 4x4 quad with a rear mount lawn mower..also a front blade for the driveways..we had almost a 1/2 km driveway so it took a long time to do haha.. i think a quad with atatchments are better then a JD or any mower.. plus when you want to go have some fun around the land you can.. the atatchments we had were called Quadavator.. Also a good thing to get if your having get togethers n whatnot... get a old push lawn mower.. fill the gas tank with a gas oil mix.then put it off in the corner of the lot and let her run.. the smoke will keep the bugs away..also if your as lucky as we were with our land, we had a nice doug out to go swimming in..haha it was sweet!.. but yeah good luck with the land lots of work to up keep but sooo much better then city living
    www.boostedalberta.com
    =[[Beyonds Dirtiest Daily Driver]]=
    Originally posted by dj_rice
    OOP or whatever that Out of Province Inspection is called
    Jul 2006
    has three pedals.
    I agree in water purifying, but reverse osmosis is junk. Go with water distillation and also buy a water softener. Not a crappy 100 dollar unit that sits on your wall, but the 4 tank, 5 thousand dollar system that works wonders.
    Not all well water. Just depends on what water pool you hit when you drilled your well. I've seen people right next door (relatively speaking) have totally different water compositions. If it's got a lot of iron in the water, then yes it could do wonders on your tanks. Go get a water analysis before jumping the gun.
    May 2005
    Mountains/Calgary
    Das Fahrenheit
    but if your minding your dollars...
    Agreed, try and find a used walker if you can. Toros and John deere are great too.
    Dec 2006
    FZ6, Ford Raptor, Audi A3 Sport Comp.
    You sir are a retard. Well water around Calgary, specifically if drawn from the Paskapoo aquifer is far softer than anything a water softener can do.
    I have lived on an Acreage for 12 years now and can honestly say that the best water system if you are on a well is to install a large cistern in your basement with a high-volume pump and smaller pressure tank. The well slowly fills the cistern so you don't stress the well itself during peak water usage times as the extra storage in the cistern can be easily accessed. Using this system the hot water tanks are 12 years old and still going strong.
    I am a hydrogeologist by the way.
    Edit* I have a 20hp John Deere Diesel tractor with a front-end loader and PTO snowblower with a 56 inch mower deck, I can cut 4.8 acres of grass in 4 hours and can clear nearly an acre of asphalt in the winter in 1 hour.
    Dec 2006
    Here are some photos of my setup:
    The John Deere
    The water system.
    Jun 2003
    YWG
    My in-laws have a cistern that holds 300 gallons in their basement. By simply aerating the water going into the cistern from the well they have eliminated any H2S smell and always have constant pressure throughout the house.
    We get our water filters here:
    http://www.waterfiltersonline.com/
    Anyone know of a better site or location?
    Just seemed fitting for this post as everyone here must use them.
    May 2007
    CALGARY
    6.2L V8
    living on an acreage is one of the funnest things u could ever do. grab a cheap ATV and throw a plow on there for the snow, a riding mower is a must. your gonna love acreage life
    Apr 2003
    S.W. Calgary
    a couple S/C'd V8's
    I'd love to live on an acreage, but land within a 1/2hr of the city is very expensive.... All I'd need is 2-5ac and I'd be happy.
    Jun 2003
    YWG
    Apparently the education system in rural Alberta needs some attention.
  1. Well Water Testing Acerage
    By Gorilla in forum General
    Latest Threads: 10-15-2008, 12:40 PM
  2. Living on an Acerage
    Latest Threads: 11-20-2007, 06:46 PM
  3. Superesc living his nickname
    By G in forum General
    Latest Threads: 07-18-2003, 01:12 AM
  4. Are you living at home?
    By max_boost in forum General
    Latest Threads: 01-06-2003, 07:48 AM
  5. Living room parking
    By SilverStreak in forum Cars, Bikes, Machines
    Latest Threads: 08-23-2002, 06:28 PM
