I bought the car new in 2001, and the title is clear with no liens. The vehicle has been in no major collisions, but did hit the tire wall at low speed at the local track. This necessitated replacing the front passenger fender and repairing the front door. I decided to repaint the entire car at that time, but the repaint had issues due to low temps in the spray booth. As a result, the paint is more brittle than it should be. There are some rust bubbles around the rear fender lips where the painter missed primer :mad:
I never wanted to sell this car, planned on keeping it forever. But there is no work in my part of the patch, and I need the money.
I am attaching some photos, and I can take more if you have something specific you want to see.
I damaged the engine when the boost wastegate hose popped off under boost and it hit 30+ psi instead of the 16psi wastegate boost it had been tuned to for breakin. Tune was by Airboy, but the failure was strictly mine as I should have upgraded the boost hose. The engine, turbo, FMIC are NOT included.
As it sits, this is what would be included;
Driveline
- Full ver8 JDM specC driveline : axles, hubs, brembo's, R180 diff, 6 speed (new front axle seals)
- Kartboy short shifter
- TIC shift linkage bushings
Suspension
- Whiteline ALK/w sport bushings
- Whiteline swaybars front and rear (adjustable)
- Group N topmounts
- JDM pink springs
- Koni yellow strut inserts
- Rear camber bolts
Interior/Exterior
- Defi BF gauges Imperial - EGT, Oil press, Boost
- Apexi AVCR boost controller
- TurboXS Knock Lite - mounted in center cluster
- STi Titanium shift knob
- Acura RDX antenna mast
- Prodrive GC-06 17"x8" wheels in "British Black" no curb rash
- Yokohama Advan Sport 245/40/17 85% left or better - no irregular wear
- Morrette projector headlamps - HID kit included but wiring needs to be re-freshed. Includes two new Bosch relays.
Pictured, but not included is the FMIC for the UR rotated turbo system.
I'm asking $8k which I think is a good price given the value of the parts in the car. If you're looking for a project platform, its a great low cost entry point.
Contact me at spec.c.wrx AT gmail
Steve
