How much does the weight of the wheel affect a car's performance?
Let's say a 17x7" wheel that weighs 15lbs vs a 17x7 wheel that weighs 22.5lbs.
I know it will affect it bit, but how much?
Thanks!
Thanks!
To add to that question. How much does 18" and 17" wheels differ in performance (Launch and accel)?
I don't know too much about wheel sizes, but i can make a prediction:Originally posted by Cwave
Bigger wheels will be faster on the straight, but smaller wheels will be better for cornering.
I'm not sure about this though.
Actually, it would seem to me that the opposite would be true.
It takes more momentum to move a wheel with more weight distributed on the outer edges. But because larger wheel means less sidewall, thus giving less tireroll for the corners.
Bigger wheels = better cornering, provided you are using similar tires just as cwave said, less sidewall roll.Originally posted by [GaGe]
But what about on the 1/4mile? I wonder how much difference it is with 17"s vs 18"s
I'm almost tempted to leave my 17"s on until after friday
Has anyone tested?
Its more the exact opposite really...I thought you were a car whiz kid! j/kOriginally posted by [GaGe]
big difference.
First time I drive with my 18's on, I almost stalled because I wasn't giving enough gas. I was too used to driving with my 16's which are much lighter and smaller.
Hmm... do you have very light-weight 16"s though? What I'm trying to do is compare same weight 17"s and 18"s.
Let me PM Importz and see if he noticed a difference.
Originally posted by buh_buh
big difference.
I just typed it the other way around.Originally posted by jonny
Another thing, tread width. Did your 18"s have a much wider tread than your 16"s? That usually makes a huge impact also.
big difference.
What kind of car are you driving? I think the amount of difference you'll notice is proportion to the amount of torque you have in your car.
Thanks!
Bigger wheels (don't have to be heavier too but this is usually the case) have a parasitic effect on torque. Because bulk of the mass of the wheel and tire package is further from the center of rotation, it requires more energy to make the wheel spin the same speed. There's no hard and fast rule that I know of for figuring out how much difference an extra pound of wheel makes in the quarter or anything like that, but it can have quite a profound effect on torque limited vehicles.
Rotating mass is worth much more then regular mass when loosing weight on your car. Say you lose 20 pounds in the wheels themselves(all 4). That would be more equivilent to losing 60 lbs of dead weight in the car(numbers are very approximate).
Also, going to a bigger wheel/tire effectivlly changes the gear ratio to the ground. Smaller wheels/tires = short gear ratio. Big wheels/tires = tall gear ratio. So smaller wheels and tires should/would give you a better 1/4 mile time if they have the same tire compound and width.
I have a whole SCC article about this where they tested 1/4mi and lap times w/ different wheel sizes. I'll put it up later.
Current Cars:
2004 GMC 2500HD 8.1L
Past Cars:
1970 Chevy Blazer, 2wd
2005 Jeep Wrangler LJ
1989 5L Mustang
1990 Jeep Cherokee
But typically when you increase wheel size, we compensate by putting lower profile tires so that the overall diameter is not affected.
Is that why the ITR comes with those 15" Wheels?
Hey Cwave,
The ITR was specificaly given the 15" wheels not only because they handle quite well but they are also very light.
Most of the other ITR owners that I talk to wont even put anything bigger on their car than 16". Like Ekliptix said, weight is everything.
A good set of Spoon, Mugen or Volk rims will forsure help you out.
VC.
The weird thing though, is that AC Schnitzer wheels are quite heavy themselves (almost 30 lbs each). At the same time, they are HUGE a$$ expensive! Why would that be?
I noticed a huge difference when I had my 17s on compared to my stock 14's..with the 14's the car launched hard but were scary at high speeds and didnt corner very well....the 17s hooked up nicely but didn't allow the car to launch like it did with the 14's. The 17s were a hell of alot better in the corners though and at top speeds
Red Deer, AB
What car do you drive? Is it an MR2? What year? Turbo?
ya 91 turboOriginally posted by Cwave
Red Deer, AB
