Ram upgrade not working so good... - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Ram upgrade not working so good...
    calgary ab
    4x4
    Default Ram upgrade not working so good...
    G'day folks,
    IE8 forced me to finally get off my arse and upgrade the ram on this gateway m-6822 laptop... Opened her up, PC2-5300S - checked with gateway - 4gig max of pc2 5300 ram - went to memory express, picked up a pair of 2gig patriot PC2-5300 Sodimms.
    Installed them - get the bios boot screen, then hangs with just a flashing cursor in the top left corner... Checked and rechecked installation, swapped the order; no change. So I put one of the 512mb sticks in the upper slot - no change, lower slot - it boots, swapped the sodimms back and forth - both work fine and memtests fine.
    Can anyone enlighten me - as I wait for the st*pid gateway tech support folks in india to call me back...
    Thanks in advance,
    Andy
    Feb 2004
    hmm i just went to buy the exact same memory.... same shit happened to me and my newer ibm laptop.... maybe they selling shitty patriot sticks.
    Sep 2006
    I bought the same Patriot sticks last week (These) and installed them in a client's Toshiba laptop, worked fine.
    May 2009
    put old RAM in upper slot and tell us what happens
    does it boot now ?
    calgary ab
    4x4
    wont boot with the old ram in the upper slot either (mentioned in original post)
    calgary ab
    4x4
    http://forums.cnet.com/5208-12546_10...hreadID=294232
    Vista 32 can only support up to 3.5gig of ram... no more...
    Feb 2004
    as long as ur laptop can support it then it should at least boot into windows where you will only see 3.5 out of the 4. Its probably a compatibility issue with the ram. And one memory must be in the bottom slot at least usually.
    Sep 2006
    Yeah dude, you can put 12 GB of RAM into a Vista 32-bit machine and it'll just recognize 3.5 GB. If the BIOS isn't recognizing it then a compatibility issue is what I'd expect. I dunno about Gateway, but I know HPs and Compaqs are pretty picky about their hardware, it would be something to look in to.
    calgary ab
    4x4
    Bios sees it fine - seems to be a vista issue - as i can boot linux livecd's and memtest with the 4gigs installed... Just vista blows chunks... Why am I not surprised...
    NW Calgary
    '10 Civic
    Edit: Yea I would check the memory compatibility on their website if you can) and just return the other memory.
  1. RAM Upgrade for Gateway 700GR
    By Hakkola in forum Computers, Consoles, and other Electronics
    Latest Threads: 03-25-2009, 08:26 PM
  2. Ram Upgrade help needed...
    By Nufy in forum Computers, Consoles, and other Electronics
    Latest Threads: 10-03-2007, 11:30 PM
  3. Laptop Ram upgrade question
    By Dooms_Bane in forum Computers, Consoles, and other Electronics
    Latest Threads: 07-31-2007, 01:24 AM
  4. LF: Stock 96-98 Civic AM/FM Radio { Working or NOT working }
    By mik in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 12-19-2006, 12:07 PM
  5. Fs:hd & Ram Ram Ram Ram Ram Ram Ram Ram
    By Crazyx88 in forum Computer Hardware & Peripherals
    Latest Threads: 09-28-2005, 09:08 PM
