Electrical / Wiring help - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: Electrical / Wiring help
    May 2005
    Default Electrical / Wiring help
    I'm definitely not an electrician - so i'm hoping someone can help me out. I'm trying to switch an old lighting fixture in the master ensuite with a new lighting fixture and while new fixture works - when ever the fixture is turned on, the bathroom fan turns on. When the old fixture was in place, the light and the fan were on independent switches and I would continue to want the fan and light to operate independently. Attached is a wiring diagram on what i'm dealing with and some of the combo's i've tried:
    NOTE:
    R1 = Red wire 1 (Hot wire)
    B1 / B2 = Black wires 1 and 2 (Hot wire)
    W1 / W2 = White wires 1 and 2 (return wires)
    G1 = Ground wire
    COMBO 1:
    Wall (R1 + B1 + B2) to Fixture (B1)
    Wall (W1 + W2) to Fixture (W1)
    Wall (G1) to Fixture (G1)
    Both switches turn on the fan and light
    COMBO 2:
    Wall (B1+B2) to Fixture (B1)
    1 switch turns on fan and light. The other doesn't do anything.
    May 2003
    -10 F150 Lariat, -10 Fusion SEL awd
    put the red to the fixture, leave the blacks connected ONLY to them selves NOT the fixture. connect the 2 whites to the fixture as well as the ground.
    C.J.
    1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
    May 2003
    I'm pretty sure you don't want to connect all three together...the problem is in the COMBO 2 the red wire is not connected...
    Should take pics of each fixtures wires as well as each switch so we can see the wiring...
    Nov 2007
    SR20 240sx / 2002 Jeep
    so you must have disconnected all wiring... and then forgot how the original fixture was connected... because it used to work before.
    blackshadows post should be the solution....
    May 2005
    It worked! Thanks black_shadow.
  1. LF: Electrical Design/Electrical Estimating work
    By Old Snake in forum Careers
    Latest Threads: 08-13-2009, 06:29 PM
  2. Need Electrical Help: 220 Volt Wiring
    By project240 in forum General
    Latest Threads: 01-29-2009, 04:44 PM
  3. Replies: 4
    Latest Threads: 01-10-2008, 03:10 AM
  4. House Electrical Switch Wiring (Help Please)
    By hussein in forum General
    Latest Threads: 01-24-2007, 01:14 AM
  5. Need Some Wiring Help Please....*Wiring GURUs Enter Here!*
    By Weapon_R in forum In Car Entertainment / Electronics
    Latest Threads: 04-21-2005, 06:38 PM
