1997 Jetta 1.9TD (turbo diesel, not a TDI). 271xxxkm's
5speed
cruise control
power locks
sunroof
OG tape deck.
100% stock.
Service performed this past month:
-Timing belt
-Crank sprocket and bolt
-Valve cover gasket
-Camshaft seal
-Oil and filter (synthetic)
-Drivers side outter CV boot (this was the ONLY part that needed to be replaced for the OOPI)
-Wiper blades
-Car was fully detailed inside and out (previous owner had a dog)
Have all reciepts for parts.
The car is in very good shape, inside and out. One family owned since new. It was a BC car (lower mainland), passed its OOPI with no problems (have all OOPI paper work), is registered in AB. Everything works like it should, it runs and drives very nice. Doesnt burn oil, runs super clean, can get 900km's to a tank on the highway.
Front tires are Fuzion ZRi's with 80+ % remaining, the rear are generic A/S's with good tread left.
The body is in great shape, although it does have scuffs and various scratches here and there, and it does has 2 small spots of rust, one on the lower leading edge of the drivers rear door (can be sean in the pics if you look close) and a small bubble starting under the drivers side taillamp on the trunk.
Interior is minty. One small tear on the back seat, bottom cushion.
Crack and chip free windshield.
$3400
