Official Short-term Investments Thread - Page 1634 - Beyond.ca - Car Forums
Page 1634 of 1782 FirstFirst ... 1624 1633 1634 1635 1644 ... LastLast
Results 32,661 to 32,680 of 35622
Thread: Official Short-term Investments Thread
  1. #32661
    Mr. Forex technical
    a tank
    Weed
    there's the lower low, do we have one more mini wave lower? I expect this to be wave 5 of C on the verge of being completed. confirmation requires price above 26.75 follow by above 32
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  2. #32662
    Jul 2006
    Victoria Park
    Anyone eyeing ACB entry? $6.50? Lower?
    Seems to be an oversold bounce happening right now, but that might be all it is. Waiting till that subsides.
  3. #32663
    (maah raahde)
    I got in at $7.02 this morning and bailed when it shot up to $7.42 shortly after. If I held on 20 minutes later, I would have hit the high of day but I was in a meeting.
  4. #32664
    Dec 2008
    Quote Originally Posted by J-hop View Post
    Picked up a small amount of largo resources this morning, looks like it could be decent. Year, month and 5 day trending upwards pretty well. Volume looks ok.
    after missing when I should have bailed on Monday exited with a reasonable gain this morning (1.69 -> 1.83).
    Nice work. Canadian weed stocks are scaring the hell out of me right now.
    Edit: into bear creek mining @2.60, see how that one goes
  5. #32665
    Mr. Forex technical
    a tank
    it will be interesting to see how gold reacts if 'it' can break above 1356.83 to breakout from this multi-month long wedge/channel/consolidation.
    those following this sector should be fully aware of the discrepancy between gold and silver meaning, one should bet on silver to out perform gold by a significant margin during the next rise which may be happening now. (Silver COT data is at a level or signal not seen since 2003) worse case would be yet another ICL into May/June. but I am fully ready if PM makes some noise now
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  6. #32666
    Mr. Forex technical
    a tank
    1356.83 broken, next key resistance 1361.72
    update: going to set a mental stop loss on gdx 22.51 and gdxj 32.83, still feels like PM is under performing and could repeat what happen in feb where this move up is just another 3 wave A=C. if this breaks will reassess
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  7. #32667
    Jan 2009
    2019 JLU /Triumph T120 Bonnyville
    I've been buying ACB when it hits 7.90~ and keeping an eye on it as it pops above 8.10, selling as it gets past that point and then re-buying when it gets down again. In the last 5 days it has been consistently been playing around those points, with some deeper dips. A couple of my gold holdings are also starting to climb, which is nice. Kicking myself for dropping out of CR and PONY when I did but oh well. Got into BIR when it was 3.90 and it's around 4.30 now, so that was a good choice to make.
  8. #32668
    Jul 2006
    NA
    Thanks for the 14 years of LOLs. Govern yourselves accordingly and avoid uppercut reactions!
  9. #32669
    Mr. Forex technical
    a tank
    again gold deeply retraces beyond what I had hope, and gdx broke below 22.51, taking my 10% profit off Jnug and moving my funds into SIL, might go back to jnug if we do get a sudden break down, otherwise I am focusing on holding more silver exposure.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  10. #32670
    Mr. Forex technical
    a tank
    Hive
    with the entire crypto shares sector begging to rebound, I am still waiting for hive to make that strong move back to the 1.8-2.20 range. Again still only 3 waves off the low and another crack / attempt to break above 1.38 as well as the down channel.
    http://stockcharts.com/freecharts/ca...UT.V,blok.v|B|
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  11. #32671
    '14 Taco
    Reallly hoping my LHS.CN continues to bounce in a big way..
  12. #32672
    Mr. Forex technical
    a tank
    Leaf.to
    Another good cannabis stock from a charting perspective is Leaf, not sure who plays this one. but it would appear the ABC down is finished with a great impulsive off the low wave (C) , now I expect sub wave ii is underway, while it has met the min 23% correction, so unless it is a very shallow wave ii which by EW definition is possible, generally speaking the 50-61% correction back to the 16s is welcomed. a good risk setup with stops under the 78% level around 15.33, if this ABC count is correct. then this stock should begin some nice up swings.
    now in general this may be a good indication for the entire sector so WEED/ACB/APH should all have good moves as well, they are more or less in their own variants of correction which have either ended or are ending.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  13. #32673
    Mr. Forex technical
    a tank
    Quote Originally Posted by SilverRex View Post
    Weed
    just to throw this in there, this is what I am expecting is happening to WEED from a EW count pattern
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  14. #32674
    Dec 2008
    Might be worth looking at the US cannabis companies after trump showed federal support Friday for states that have legalized it. Looks like it’s having some effect on Canadian companies but I think that will be short lived.
  15. #32675
    Oct 2008
    South of Calgary
    is broken
    Not sure how many of you are trading AMD but it looks prime for an upswing. A bit oversold and they typically rise before earnings on 3/5. Bought a position this morning.
  16. #32676
    Mr. Forex technical
    a tank
    Silver Juniors are slowly coiling higher/breaking out
    http://stockcharts.com/freecharts/ca...CB%7CH14,3%7C0
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  17. #32677
    Feb 2015
    SK
    SilverRex, I know you exited your JNUG a few days back. Just curious where you think gold is headed now? I know GDX dipped below your mental stop loss. GDXJ only went a penny lower at 32.82. I am still hanging on to a position...as it seems to want to grind a little higher. Any thoughts?
  18. #32678
    Mr. Forex technical
    a tank
    Quote Originally Posted by Magic8Ball View Post
    yes i exited Jung, when it broken a level i had set in mind. over all i am still leaning towards a breakout in this sector now or few months down the road, so i moved into SIL instead. Even if gold/silver does breakout from here, i am all positioned for MT to LT, trading in and out of Jnug was just a swing trade for me.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  19. #32679
    Mr. Forex technical
    a tank
    SPX
    I posted this a while ago when spx first made 5 waves down to the bottom of the rising channel. I took this opportunity to move the rest of my cash holdings into the equity index. I suspect we are now on the 2nd upswing which should be part of some triangular pattern with breakout to the upside. Once we get the breakout to ATH again, it will be time to begin unwinding position in anticipation of a much larger correction or a multi year topping which would mean a SM crash.
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  20. #32680
    Mr. Forex technical
    a tank
    crpyto shares starting to catch fire.
    BTSC leading the charge with 250% off the low. while my holdings are small and have been buying the dips every now and then, I am taking my profit here for BTSC/BTCS (44%/22%) respectively. still waiting for hive, mara, bloc to catch up
    http://stockcharts.com/freecharts/ca...C,HIVE.V,HUT.V
    _________
    2019 IS350 AWD
    20xx NX350 AWD
  1. The Official Trump Thread
    By ZenOps in forum Society / Law / Current Events / Politics
    Latest Threads: 04-19-2018, 04:00 PM
  2. The Official ~Your Office Pic~ Thread
    By legendboy in forum Careers
    Latest Threads: 05-29-2003, 09:24 PM
  3. Replies: 14
    Latest Threads: 04-09-2003, 12:28 PM
  4. The "Official" who is going to win the cup thread!
    By Speed_RaSiR in forum Sports, Health & Fitness
    Latest Threads: 04-08-2003, 10:41 PM
