the heater in my Integra seems to be warm even though I put it on the highest fan speed and it is set at the red zone..meaning its not hot enough in the freakin cold...any possible solutions to this?
making it up as I go along....
new thermostat.
are u sure? cause I just bought the car 3 weeks ago....Originally posted by Spenser
new thermostat.
if so, how much does it cost? and how do you install it?
they are cheap, under 20 bucks, it's about a .5 hour charge to change one at a shop. you don't need a new one, maybe just a hotter one
how hot should it be when the heater is set to the highest level.....
beware, it might be your headgastket..we had that problem in our windstar, we bought a new thermostat and it didn't work then the mechanic said it was the headgasket...ouch $1200 + bill
omg. so much nonsense in this thread.
dude, is your car actually warming up and staying warm in the cold? i mean as in your actual temp. gauge readout. if it doesnt stay at the usual temperature, then get a higher temp tstat. if it does, then u might just need a new heater core or have your old one flushed out
NooooooooooooooB'ssssssssssssss
I just changed my thermostat on my B16 and it's really easy. Its so easy the place that did it did'nt charge me for it when he did a rad flush (he did the flush for $40 or $50 i think). Don't go get a $20 thermostat, go to Honda it will be $45 it comes with the gasket. Don't forget your B18B is'nt much diff than mine...actually they are pretty much the same.
If the heat in your car sucks than it might be your Heater core but most Honda's past a certain amount of years or KM's the heat starts getting shafty, I have had that problem in 3 of my previous Honda's.
Guess I am just lucky, I've owned 7 hondas and never once needed a new heatercore. But you're definetly right about the coolant flush, improper coolant mix can make the heater not so hot.. Seemed to fix any heating problem I've ever had.Originally posted by HB Infamous
see just flush that shit and it should be fine something I did'nt do on my other Honda's
heater core can get plugged from not using it.Originally posted by Primer_Drift
Agreed, I've seen some cars flushed and what appears to be dijon mustard comes out hahaOriginally posted by GTS Jeff
just got mine flushed and holy fuck is it hot
