McLaren MP4-12C - Page 2 - Beyond.ca - Car Forums
Page 2 of 2 FirstFirst 1 2
Results 21 to 33 of 33
Thread: McLaren MP4-12C
  1. #21
    As with the McLaren Formula 1 car, a shift can be actuated either by pulling or by pushing on the rocker. The rocker moves with the steering wheel, rather than being mounted on the steering column, so that if a gearchange is needed while lock is being applied the driver does not have to fumble around to change gear.
    The rocker itself incorporates an innovative feature created by McLaren engineers called Pre-Cog. The name stands for pre-cognition, literally 'foreknowledge'. The rocker on the 12C has two positions with a slightly different haptic (or feel) for each. The driver applies first pressure to the rocker and it informs the gearbox to get ready to swap ratios, thereby saving time – latency – between the message being sent and the gearbox being primed to act. The second pressure confirms that the gear should be changed and the torque handover is completed in milliseconds.
    "What Pre-Cog actually does is initiate the shift process by priming the clutch and torque handover – it takes significant time out of the process," explained Dick Glover, Technical Director McLaren Automotive.
    "It's a little bit like the first pressure on a camera shutter button. There's no requirement for the driver to use it but it is more satisfying and engaging if you do. The SSG also promotes seamless shifting in which the driver doesn't have to reduce engine power at all – rather than the gearshift slowing you down, it actually speeds the car up by recovering the energy of the crank spinning as it drops engine speed," he said.
    Nice improvement on the DSG with the pre-cog function.
    Another feature that helps the 12C to handle at a new level is a development of an electronic system used by McLaren's 1997 MP4/12 Formula 1 car, – Brake Steer. In essence, it is a system that brakes the inside rear wheel when the car is entering a corner too quickly to make the desired radius. Under normal circumstances the front would wash away wide of the apex the driver wants to touch: in other words, the car is in a state of understeer.
    Brake Steer manages the tendency of a car to wash out and brings its nose back on line. It assesses the steering angle to determine the driver's intended course and applies the inside rear brake to increase yaw rate and resume the desired course.
    The system also works on acceleration out of a corner when the inside rear has a tendency to spin, allowing the driver to put power down more quickly. It controls what a limited slip differential would do and obviates the need for such a complex and heavy unit, thus saving more valuable kilos.
    This will be a weird one... the car won't have a LSD to cut weight. The SLR didn't have LSD and used ASR (which is basically Brake Steer) and I wasn't a fan of the system because you lose a lot of feel when you start stepping the rear end out. Either McLaren has figured it out, or it's a car that's tough to "drift" out of corners.
  2. #22
    Apr 2003
    F10M/F87/NA2/W220/V90/E46ZHP/SE3P/DC2
    Hrm, no footage of Jay driving the test mule?
  4. #24
    Sep 2002
    Zimbabwe
    F355 Challenge/996TT/FD3S/968 Turbo/NSX
    Damn, I didn't see a cup holder. That's a deal breaker........
  5. #25
    Jun 2005
    Calgary Alberta
    Perpetual Test Drive
    Will it be coming to North America? How will it be distributed?
    War is Peace. Freedom is Slavery. Ignorance is Strength.
  6. #26
    ___________________________
    Wow Mahle built the engine awesome.. . cant wait..without reading through the entire thread will it be available in Canada?
    Red Deer, AB
  7. #27
    Sep 2006
    They're claiming 1000 a year with a quarter going to UK, a quarter to USA and the rest distributed across the world.
    I imagine that, if you're interested, they're available anywhere.
  8. #28
    Dec 2008
    A semi-detached home from 89Coupe (hahahaha)
    A Gallardo from SDS (hahahaha)
    Originally posted by Mibz
    ... I imagine that, if you're interested, they're available anywhere.
    It's not that simple.
    However, I would imagine they will be officially offered in the Canadian market. My guess would be one or two franchises for the entire country. Maybe through the two Bugatti dealers, or a similar set-up where the McLaren is offered alongside other luxury brands.
    If the US is getting ~250 cars, Canada will likely get ~20 cars.
  9. #29
    McLaren did some development work on the top gear circuit. That's almost like fudging benchmarks haha.
  10. #30
    Apr 2003
    ^^ the dude in the middle looking at the laptop looks like Gordon Murray
  11. #31
    Yes. Canadians will be able to order these cars new from the factory.
  12. #32
    E550 Coupe (M278)
    Call me crazy but... I like the looks of the original better.
    -James
    Current beast: E550 Coupe (M278)
    Previous beasts: AM Vantage, E90 335i (modded + JB4 Map2), E39 M5
  13. #33
    Jul 2005
    Calgary, Alberta, Canada
    2017 Ford Fiesta ST
    Originally posted by rage2
    That F1-GTLM in the middle.... oh my god... my favorite race car ever
    Geek
  1. McLaren mp4-12C article
    By syeve in forum Automotive News
    Latest Threads: 06-08-2010, 08:38 PM
  2. McLaren MP4-12C GTR Rendering
    By scat19 in forum Automotive News
    Latest Threads: 02-21-2010, 09:45 PM
  3. McLaren Launches MP4-25. Ferrari cries. Lawl.
    By rage2 in forum Formula 1
    Latest Threads: 01-31-2010, 01:24 AM
  4. McLaren MP4-12C
    By flipstah in forum Automotive News
    Latest Threads: 09-29-2009, 09:37 PM
