Help! E36 being more annoying than a high maintenance high school girlfriend - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Help! E36 being more annoying than a high maintenance high school girlfriend
    '09 Dodge Challenger
    Default Help! E36 being more annoying than a high maintenance high school girlfriend
    hey guys im stumped, need some help.
    My '94 320i died on me while on the road, i was driving for a half hour, and went to the automatic car wash and it was ok for 20 min. after coming to a stop, i accelerated to 3000 rpm and the car stuttered and then died. i tried to turn it on but it only cranked, it wouldnt fire up.
    - First thing that came to my mind was the DME got wet, so i popped the cover open and it was bone dry, there was even some dust on it. Checked the relay and still no go.
    - Second thing that came to my mind was the fuel supply. So i changed the relay. still no go, then I changed the fuel pump, still no go.
    - Third i thought it might be spark, so i grabbed some quick start and sprayed it into the intake, and the car ALMOST starts up, it'll ignite for maye a second and then die.
    Where should i go from here guys? Im taking the bus for now and im getting tired of the loud kids that take my route...
    Help.
    2000 BMW 540i/6-spd & 2008 Triumph Street Triple
    My guess would be crank or cam position sensor (CPS)... quite common on the E36.
    Search Bimmerforums.com for answers. If that doesn't work take it to a independent BMW mechanic... don't just throw parts at it, it'll end up costing more in the end (that fuel pump you replaced was probably around $400 just for the part!).
    Jul 2006
    has three pedals.
    Hmm my car would run, but very poorly, even with a faulty intake cam shaft sensor.
    Jun 2008
    see-town
    Arguing over the internet is like cheering on the Oilers. Win or lose, you're still a dumbass.
    Originally posted by G-ZUS
    you mack daddy
    the C-spot
    O.P.P.
    Default Re: Help! E36 being more annoying than a high maintenance high school girlfriend
    Help.
    Eric, here are my replies to an older thread someone else posted awhile ago....
    Originally posted by cocoabrova
    Could also be your fuel pump relay, or the actual fuel pump. Or does it happen after you wash your car? OBD0 E36's are notorious for the DME's grounding out from accumulated water sitting underneath them (after going thru a touchless-type carwash or heavy rainfall)
    Well first off, stop using the touchless car washes if you can and just use the self-serve car washes, as the amount of water and water pressure is about half of what it would be going thru the touchless wash . Just by doing this, you will have eliminated your problem, but just as a precautionary measure, read over THIS page to gain some insight as to what exactly happens. Then I would search the net for some kind of fix to cure this i.e. building some sort of platform for the DME to avoid sitting in the pooled-up water.....
    Good luck
    The same exact sypmtoms happened to me right after washing my car, except it only took my car 10mins. to die Couldn't figure it out for the life of me, so I just stopped using the touchless car washes and !Voila! car's been running great ever since. The DME is obviously dry now, but you probably fouled your sparkplugs from all the cranking over. Change out your plugs and you should be good, but there is the possibilty that your DME fried, but get your plugs changed first and go from there. Call me if you want me to bring you in some.......
    Jul 2007
    Blue boy
    I hate the design of these cars. LOL I sold my 325 coupe to some guy last year and told him like 5 times(not exaggerating) not to take it to a touchless carwash and just wash it at home. He called me a week later from BC asking whats wrong with it because it won't start. He said he's at a car wash. I was like .
    Jul 2006
    has three pedals.
    I must admit, if we didn't have quirks, what would we bitch about online or try to diagnose? haha!
    Dec 2004
    2010 WRX Limited
    oh the e36.. fun car
    But once they get old.
    Everything just starts to go.
    alright, sounds good thanks a lot guys, i'll try some of the things suggested and let you know either friday or saturday how it goes.
    cocoa, u have a pm...
    Aug 2008
    Lethbridge
    '08 AW E92 335i
    pics of the high school gf?
    bimmer,benz, or bentley
    lmao, if i can fix it maybe i'll post the pics...
    But now my worst fears have come to light: The DME is fried and i know BMW charges an arm and leg for them...
    Anyone got a DME out there that i can grab from?
    I thought you said the DME and the compartment were "bone dry"???
    'Cause that was my first guess when you said it quit after the car wash.
    Happened to my '93 325is... got a new used one for $350 from a member of Bimmerforums.com.
    Before you replace the DME make sure you clean out the 2 clogged cowl drain hoses behind the motor (dirt, leaves, etc.) or it will just happen again.
    Try Manchester on Glenmore Tr., they will likely have one... though probably expensive. You will also need to do some research on Bimmerforums to figure out which one you need.
    Jul 2007
    Blue boy
    try drying it out you might get lucky, my friend did
    yeah it was bone dry (even had dust on it) but it looks like it was corrosion over time from previous wetting got to it.
    Default car for sale
    still looking for a dme, or else i guess the car is for sale now guys if anyone out there wants to fix it. if you want details, pm me.
    Feb 2009
    Family Hauler
    Oh yea great idea listing your car FS in the same thread that lists it as unreliable!
    Default Re: car for sale
    Did you try calling Manchester? They will likely have one. If not Shenni's Auto Trend might be able to locate one.
    OK, I just saw your ad on Kijiji for a DME... that passive searching will get you nowhere!
    If you haven't called Manchester Auto Parts or Shenni's, do it NOW!
    If you have, with no luck, do this:
    1. Sign up for Bimmerforums.com
    2. Scroll down to "Bimmer Parts For Sale"
    3. Search "e36 dme"
    Took me 3 minutes to find at least 5 DME's for sale for as low as $80 shipped!
    The 320i might be different than the 325i, so you need to know if yours is a "red-label" or "black-label" (I think) and the prefix at the end of the bar-code number, most likely "413".
    Don't sell it for next to nothing because you're too lazy to spend a couple hours doing some research... 'cause that's all it will take to save your ride dude!
  1. Priceline is being a little annoying
    By RickDaTuner in forum Travel and Vacation
    Latest Threads: 02-07-2010, 08:30 PM
  2. Input Survey for School Naming - New West Calgary High School
    By urban.one in forum Society / Law / Current Events / Politics
    Latest Threads: 05-22-2009, 09:04 AM
  3. fs: MY E36!! 1993 BMW E36 325i, M3 replica +more!
    By takemtochurch in forum BMW Marketplace
    Latest Threads: 03-25-2009, 12:18 AM
  4. fs: MY E36!! 1993 BMW E36 325i, M3 replica +more!
    By takemtochurch in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 03-14-2009, 05:57 PM
