Home Shelving Help - Beyond.ca - Car Forums
Results 1 to 20 of 34
Thread: Home Shelving Help
    Calgarian Living in Edmonton
    Default Home Shelving Help
    My dilemma is I have a wire shelving rack in my closet, and from putting too much weight on one side, the shelving came apart, I tried putting it back together but no dice, the problem is, theres 2 white screw thingies that go into the drywall and then 2 nails that go into the 2 white things, and when the nail goes in, the screw opens up 2 hooks that grabs onto the drywall....since the weight pulled it out, the holes are too big to hold the screws in place now, what are my options to fix this?I want to use the same holes as its aligned and centred...any help would be appreciated as I have no home improvement expertise
    Originally posted by GTS Jeff
    Dec 2006
    Lease
    Trying a bigger size butterfly anchor
    Once those holes get bigger, it needs bigger things to fit snug in there.
    Thanks for the info Tom
    I was thinking of doing that but thing is, the white screws that plank out, the nails that go into them go through the holder that holds the wire shelving up....unless I'm supposed to get rid of the white screws entirely and screw that gadget through the holder into the wall?
    Dec 2006
    Lease
    Can you take pic?
    BTW, How are the twin turbos doing??
    Exactly like this, the middle right thing is not staying up anymore
    Dec 2006
    Lease
    ^^^ I meant a pic of YOUR issue, with the enlarged holes, etc...
    click for larger version
    The white screw things arent grabbing into the wall anymore once the nail goes in, since the hole has been stretched, my solution was to put tons of glue in hole, put screw in, nail it in and wait for everything to dry ...
    Dec 2006
    Lease
    IN MY OPINION as a do-it-yourselfer... yea, just buy the "butterfly anchor" in replacement of the "white thingys" as you call it... What happens is that the 2 metal "wings" goes into the hole, and as you tighten the screw, it spreads, hooking onto the backside of the drywall. You know what I mean???
    Disclaimer This is only an educated opinion as to how I would appoarch this issue. There may or may not be other ways. Readers and OP are fully responsible and liability to ensure this suggestion would work for their appication. TomcoPDR not responsible for any injuries, deaths, loses as a result of following this repair suggestion. TomcoPDR not responsible for Dj_rice banging some fat-ass chick on wire shelves again and causing bodily injuries from failed fastener.
    I'll take the parts and ask a Home Depot guy what to do, thanks for the info and laughs
    Dec 2006
    Lease
    Don't forget to enter my home improvement contest, a chance to win either a $50, $25 Home Depot gift card. http://forums.beyond.ca/st/278708/co...pot-gift-card/
    I live in a high rise condo, I have no home improvements to do to enter sadly , I do plan on tiling my balcony where the BBQ is on, but that won't be til after winter
    Raft
    Good dating advice!
    I've planted my flag on Nothingburger Hill. Can't walk back from that stance now.
    '16 F-150 Lariat 5.0
    Originally posted by ExtraSlow
    Good dating advice!
    Dec 2006
    Lease
    You get it done?
    I will be going to Home Depot 2morrow after I get off work, will post results
    An update, so I went to Home Depot and got these Hollow Wall Anchors as pictured below in 1/8" sizing, followed the instructions, but I guess the size I chose, was almost the same size as the hole I put it in, or the drywall was weak but it did not work, and now the hole is bigger than I started with and the anchor fell behind the wall since I couldnt yank it out, so now the hole that started as the size of a pen, is now, almost like a nickel/quarter
    To remedy this situation, I went back to Home Depot and bought "Awesome Anchor, The Oversized Hole Repair Anchor"
    I will post results/failures 2morrow
    The Awesome Anchor Oversized Repair Hole fixed one side of the problem, the Hollow Wall Anchor fubared the other side...followed these instructions as per this video
    But it did not anchor out after screw went in, it gripped into the drywall and the whole anchor started spinning and thus went right into the back and made an even giant hole that I can fit my index finger through....
    So now, I assume my only option is to patch the hole and start over? And laugh it up, a simple fix ended up in epic failure for me...FML
    Feb 2008
    Not Aspen
    teslo murdel free
    Hahaha oh man. You shoulda just cut a piece of 1" x 1" or heck a 2" by 2" or 2 by 4" cut it to length (12" or however deep the shelf is) and screwed it to the wall under the shelf.
    Dec 2006
    Lease
    Why didn't you listen to my suggestion with the butterfly anchor?
    I did, I used a variation of it...the hollow wall anchor as per the Home Depot guy advise but my guess is the surrounding hole, all the drywall was cracked and etc which is why the anchor did not grip, it just acted like a drillbit and went right through....but yeah, both holes are exposed now as the holes are bigger than the stuff I bought, so now I will be cutting a square out and patching it up
    Any tips on how to do the patching TomcoPDR?
  1. WTB: Shelving unit
    By black_radiation in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-13-2007, 03:23 PM
  2. FS Shelving unit
    By gimp in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 03-27-2007, 11:08 PM
  3. FS lrg desk and shelving unit
    By civicrider in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-28-2006, 11:23 AM
  4. WTB: Metal shelving, Work bench and heater
    By dieselpower91 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-03-2006, 10:09 AM
  5. Garage organization/shelving
    By gorillam in forum General
    Latest Threads: 12-26-2004, 07:43 PM
