Racing harness belts question... - Beyond.ca - Car Forums
Results 1 to 20 of 32
Thread: Racing harness belts question...
    Calgary Alberta Canada
    08 BMW 328i, 03 Turbo SVT Focus
    Default Racing harness belts question...
    Just wondering how these install into a car...
    Can anyone explain? To me it looks like the top buckle can belt into the rear seat belts? And then the two bolts on the side have to be bolted into the floor? Yes, no, maybe?
    If anyone can explain how these are installed that would be awesome! Thanks!
    Feb 2003
    DT 780
    LEXUS LX470
    i thought they are designed to connect to a roll cage?? not sure.
    Tap, Rack, BANG!
    Jul 2002
    Cowtown
    2008 CSX Type S, 2008 BMW 335I
    The two side ones are supposed to be drilled into the floor but i bolt them in with the existing seatbelt. And the third point would go in between to where the rear seats meet in the back. You can bolt it to an existing bolt in the back but if it's not straight with your seat then you will have to drill a hole through the floor.
    Ok. I understand the rear... I think... but the sides... there are two of them, how do you connect them to the existing belt? Use the passenger side as well?
    I just used the stock mounting points on the side, then the babyseat clip in the rear.
    There should still be one on each side.
    I might have to check yours out, Kevin. I understand using the rear stock clip. And the right side can use the stock clip. But I'm still not sure of the left side (relative to when you're sitting in the car).
    haha you won't be able to check it out until April
    But even a stock seatbelt is a 3 point.
    I can show you on your car.
    I think I'm just a retard today.... I understand now. duh. Thanks for all the help everyone!
    i connected my back one to the seatbelt bolt under the rear seat but the baby clip bolt sounds like it might be better.
    I wonder if these are more reliable or less reliable than stock seatbelts. They would take longer to get out of, and if not installed properly they might not give you enough restraint.
    07 Mazdaspeed 6, 89 Mustang LX
    The baby clip is only better if its reinforced. If its like the ones in my subie, its just a plastic spread anchor through a drilled hole in the parcel shelf. I definetly wouldn't stake my life on that taking all the force of me hitting the harness hard in an accident. I've got an H harness, and I went back to the stock seatbelt mounting points in the back, and the stock points on the sides. Depending on how your car, the point on the inside (against the console) could be on the seat or it could be in the floor. Either way, if you want to keep the stock 3 points and have the harness as well, its easy to slip the eyelets for the harness behind the stock belts and have the ability to use both. Just make sure you have enough engagement length on the bolts and you'll be fine.
    I don't beleive I have a baby clip in my new car. Would it be okay to go down at a 45 degree angle to the clips in the rear seat?
    45 degrees is the ABSOLUTE maximum, do not go any steeper than that, or you risk a compressed spine in an accident.
    Whoa. Good to know. I was just estimating... I'll have to measure to see what it actually is. Thanks for the info!
    On my car, running to the rear seat anchors it works out to about 35 degrees or so. Most 2 doors of similar dimensions should probably have a similar angle. A little over isn't too bad, just be aware of the possibility. When you get into an accident, if the harness is anchored to the floor or at a steep angle it won't be able to stretch the way it should to absorb the energy and you'll end up with a messed up back.
    Sep 2003
    996 911 Turbo
    I wouldn't go with the baby seat anchor either. The rear is simply the seat belt mounting for the rear OEM seatbelts. For the fronts what I did was mount the left side to the bottom where the OEM belt mounts. Should be a big bolt going to the chasis. If the end of the harness is a clip style then you should have received a loop style bolt that screw into that spot and the harness simply clips onto the loop. For the other side just mount it where the buckle mounts to on the seat frame. Worked for me following Sabelts instructions!!
    Sep 2002
    Calgary, Alberta, Canada
    Is this going into a track car, or drag car, with a roll cage? If not it's pretty cheesy.
    Originally posted by Arash Boodagh
    Before I start pwning all the members with my findings.
    Plus, is it true you can feed a pig elephant dong and it will still grow and build meat?
    rx7_turbfoags best friend
    Toma the homophobe?
    Sep 2003
    Yeah, but, look at who you're talking to
    Sep 2002
    Was that comment in support? I was not sure how to take it. I don't understand that type of stuff. Believe me I have some cheesy little touches on my car too, but an all out racing harness in a street car with no cage is way over the top.
    Toma the homophobe?
    Sep 2003
    996 911 Turbo
    What if you have sport seats??
  1. FS: Guyon Racing 4-point harness
    By Neons4life in forum Automotive Parts
    Latest Threads: 01-04-2006, 08:27 PM
  2. FS: Racing Seat w/ 5pt Harness
    By speedyturtle in forum Automotive Parts
    Latest Threads: 08-24-2003, 12:09 PM
  3. timing belts
    By ecstasy_civic in forum General Car/Bike Talk
    Latest Threads: 07-05-2003, 11:40 PM
  4. using bucket seats with stock seat belts
    By REFLUX in forum Performance Modifications
    Latest Threads: 04-22-2003, 01:42 PM
  5. MSD injector harness plug question
    By Hollywood in forum Mechanical
    Latest Threads: 03-09-2003, 04:47 PM
