Hi !
I drive a 1998 Chev Lumina LTZ with the 3.8 engine and has 90,000 miles on it..
2 weeks ago I noticed it starting to lose coolant from the reservoir tank. Once per week (300 mile) the reservoir tank was empty. There were no signs of leaking under the car. There was also no sign of water in the oil or oil in the water.
I took it to a mechanic friend who thought it was the water pump. He pressure tested everything and there were no problems. He replaced the water pump just in case. This was not the problem as the leak continued at the same rate. I then added ‘Bar Leaks’ to the coolant. Again, the coolant lose was the same.
I then went to my local GM garage. Once again they pressure tested everything. They also did a ‘dye & black light test’ and found no fluid problems. After extensive testing, they decided that perhaps the rad cap was faulty so they replaced it. Guess what – one week later, the coolant lose is still the same, and I’ve pumped almost $400 into this car over the past 2 weeks.
Can anybody help with this one ????
Many thanks in advance........
