Jimmy's Aristo Build - Beyond.ca - Car Forums
Results 1 to 20 of 25
Thread: Jimmy's Aristo Build
    Feb 2009
    E46 M3 Turbo, JZS161, UCF30, BP9, S30
    Default Jimmy's Aristo Build
    So when i first got this car, it was a dirty old dog, let me digress;
    This is what the car looked like when it came to Canada
    Somewhere between the previous owner, and the day i went to see it this happened:
    The night i brought her home
    Specs:
    -91 Aristo V
    -Garson VIP kit
    -Work Meister 18x10 18x12
    -Leather
    -Swapped to 5spd
    -1.5 way diff
    -Blown kei office coils
    The bad:
    -no 3rd gear, transmission is fucked
    -diff is leaking
    -rear brake calipers are slapping the rims because they're missing bolts
    -blown coilovers
    -strut mounts are toast
    -blown turbos
    -blowing oil
    -front and rear bumpers were ripped off
    -car was previously pink, was coated with a shitty black paintjob which is now peeling
    -needs a lot of body work
    -turn signal lever broken
    -extremely cloudy headlights
    -stock exhaust system with weld on mufflers, mufflers are rusted and have holes in them
    -coilpacks are cracked
    -extreme p/s leak
    -all 4 rims are bent, 2 front tires are flat
    Haltech Factory Trained and Elite Certified / AEM EMS and Infinity Factory Trained Tuner / ECUTek Factory Trained Tuner for FRS-BRZ and R35 GTR / HKS Pro Tuner / Apexi Power Exel Certified Tuner
    Proud to be a "hater" that defends Authenticity
    Feb 2009
    So i spend a week working on it, getting it semi decent for the car club cruise to sylvan lake, here is the result;
    -USDM steel turbos
    -Custom downpipe
    -HKS exhaust system
    -Bridgestone NPG coilovers
    -Put the bumpers back on
    -duct taped the giant crack in the wing (yes i know, still ghetto)
    -fixed brakes
    -fixed diff seal
    -new coilpacks, plugs, connectors, bypass hoses, valve cover seals
    -flush all fluids and replace with OEM toyota fluids (except engine oil)
    -polish headlights and replace with HID's
    -new tires and fixed 2 of the 4 rims
    -HKS Fcon Vpro
    -HKS boost gauge
    -brake upgrade
    -replaced tranny and redid the swap properly
    So i also decided to mess around on the track for a couple nights
    She's parked again, and here is the new build:
    Electronics:
    HKS Fcon Vpro 3.3
    HKS 3 bar map with linked charge temp sens
    HKS AFK (wideband / knock amp)
    HKS EVC boost controller
    HKS Boost / EGT gauges
    Engine:
    Garrett GT40R Riemer hybrid
    Custom exhaust manifold
    HKS racing series wastegate
    HKS SSQV Racing Valve
    RCTS Downpipe
    HKS Hi-power exhaust system
    HKS SMF assembly intake
    HKS 264 camshafts
    HKS cam gears
    HKS timing belt
    JZA80 water pump
    Rb chromed intake
    Rb chromed tbody
    Rb chromed timing belt backing cover
    Rb chromed cam bolts
    Rb chromed oem pulleys
    MVP clear spark plug cover
    Fuel System:
    HKS fuel rail
    HKS 1000cc injectors
    HKS FPR
    Sard fuel pump
    Cooling:
    Mishimoto rad
    Mishimoto twin fans
    Titan alum rad hose
    HKS GT Type intercooler
    RCTS custom p/s cooler
    RCTS custom oil cooler
    Drivetrain:
    R154 remote mount shifter swap
    RPS Max series clutch
    RCTS solid shifter bushings
    RCTS driveshaft
    TRD LSD
    Suspension, Brakes, Footwork:
    Bridgestone NPG coilovers (soon to be changed to HSD Customs)
    Work Meister S1 (3pc) 18x10 18x12 Kumho Ecsta's all around (street)
    SSR Koenig 18x10 18x11 Advan neova (race)
    Stillen / Brembo combo rotors with Mintex Extreme pads & stainless steel brake lines.
    Body / Interior:
    Garson VIP door caps and side skirts
    Garson VIP wing (picnic bench =P )
    Garson D.A.D front table
    Mac Brick VIP front and rear bumper
    Lexus grill
    Recaro drivers seat
    Takata 4point harness
    Momo F1 concept steering wheel
    TRD shift knob
    Toyota window visors
    Cleared out headlights
    Car is on jackstands right now, should be finished by spring, pretty much have all my parts except for the injectors, and fuel pump.
    Ran 418whp on stock boost before i started pulling it apart.
    Calgary,ab
    94 SR20DET 180sx
    Looks good man i like it
    91 Skyline GTR(Sold)
    93 RB20DET Powered DropTop 240sx(Sold)
    86 RX-7 GXL(Sold)
    99 Dodge Dakota
    91 Honda Civic(Sold)
    90 Honda Crx Si(Parted out)
    95 Honda Civic(Sold)
    99 B16 Honda Civic Si Coupe(Sold)
    94 SR20DET 180sx
    May 2003
    1988 Accord, 1990 4Runner SR5
    Damn Jimmy look at you go... I used to see that thing near my house all the time, looked beat to shit.
    Good luck with the build.
    Dec 2008
    X100 | A80
    Still havent been in this thing.
    Ready by next spring though !
    Originally posted by Keiichi Tsuchiya
    The Hachiroku really brings out the beast in you.
    It's like the moon that changes a man into a werewolf.
    That is the magic of the Hachiroku.
    Feb 2008
    Applewood, Calgary
    1988 300zxt, 90 jetta
    Dude that is so fucking baller.
    This build deserves a cookie.
    If you take anything I have to say seriously, you're gunna have a bad time.
    1988 300zxt. gt35, stance coils, etc.
    1990 Jetta VR6 Daily, "stock"
    Originally posted by ercchry
    people are dumb, kids need to stop playing in the streets, SW soccer moms are the worst kind of people, the end
    Apr 2007
    66 Accord
    Is that a D-Max VIP Front Table? If So I wonder what the one for my car looks like...
    Feb 2009
    It's a Garson D.A.D table, got an extra one for JZS147 if you want it :P
    Jun 2007
    can't wait to see the finished product!
    Dec 2003
    German
    Nice build! That table is awesome
    Definitely my favourite Aristo!
    I've driven this car before it was Jimmy's... I want...
    Jun 2006
    the ladies crazy!
    Sick cant wait, are you keeping it black?
    Life is a Gamble.
    Feb 2009
    yup, she's going to get a fresh coat of black in the spring.
    Jul 2006
    has three pedals.
    Are you keeping the spoiler? Is it 3 piece?
    Feb 2009
    yup keeping the batwing as well, it's a 3 piece, but it's molded to the body.
    Feb 2009
    Some more pics:
    Pulled the front of the engine all apart, cleaning everything, getting it ready for the new waterpump, torsional damper, cams, cam gears, timing belt, and back plate.
    turbo's are coming off next so i can test fit my setup and get my downpipe fabbed up.
    Feb 2009
    Mar 2008
    https://t.me/pump_upp
    /85' Corolla GTS AE86 - 20V /06' X-Runner
    This cars getting even more boss. Nice work Jimmy.
    Ray
    Feb 2009
    well i finally got those wretched twins off, and i just test fitted my turbo to see what it would look like under the hood. still need to clock it, and get my custom manifold mocked up, but it'll look nice when it's done!
    Feb 2005
    Land of cows
    Calgary Transit
    Nice work...is the previous owner of this Aristo named Ken?
  1. Replies: 87
  2. FS: 1991 Toyota Aristo JDM
    By Cornfed in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 04-03-2007, 09:17 AM
  3. Daily Driver: Soarer or Aristo
    By avow in forum General Car/Bike Talk
    Latest Threads: 03-26-2007, 12:40 PM
  4. opinions on Toyota Aristo's
    By carter_prelude in forum General Car/Bike Talk
    Latest Threads: 12-08-2006, 09:49 PM
  5. Toyota Aristo
    By Ichigo in forum General Car/Bike Talk
    Latest Threads: 11-11-2003, 02:06 PM
