FS- Mac Tools, Snap On Tools - Mechanic Set - Beyond.ca - Car Forums
Results 1 to 2 of 2
Thread: FS- Mac Tools, Snap On Tools - Mechanic Set
    Edm
    yur moma
    Default FS- Mac Tools, Snap On Tools - Mechanic Set
    Mac Tools - Tech 1000 Tool Box w/ Full Sized Side Cab / Locker Black
    Box / Side Cab is in great Condition - Few Minor Scratchs Etc From moving it around.
    Otherwise in AWESOME Condition - Paint Looks great
    Stainless Steel Top
    Magnetic Tray
    Snap On Creeper
    Mac Tools - Creeper Keeper
    All the Sockets - Have Socket Holders For it. As you can see in the pictures
    Most of the Wrenchs Have Holders also.
    As Weird as it is, i have a SNAP ON Cover for the box - If you want it
    Snap on Bolt Grip Puller Set - CJ2001P - Huge Set NEW
    Snap On 48 PC SAE + Metric thread restore kit - RTD38 NEW
    Snap On Radiator Resivour Sdaptors TA32A and TA36GM - For Adapting the Snap On Pressure Tested to the Resiviour
    Mastercraft Tap and Dye Set
    Trouble Light
    3/4 Drive- 12 Point - Shallow - Chrome - Set 7/8 To 2 1/2 Inch! Craftsman
    Mastercraft Impact Sockets 1/2 Inch Drive 8mm to 21 MM - 10 PC - 6 Point Deep
    Craftsman Chrome - 10mm to 27mm - 12 points 1/2 in drive shallow set
    3/8 Drive Chrome - 6Point - 9mm to 19mm deep
    3/8 shallow chrome -= 6pt - 9mm to 19 mm
    1/4 Drive deep - 3mm to 13mm - 6pt
    1/4 drive shallow - 3mm to 13 mm
    Snap on 1/2 impact 12 point - Impact Shallow Socket - FOR DRIVELINE Capscrews
    1/2 to 3/8 Impact Adaptor - Snap on
    3/8 Universal Wobbel
    1/2 Mastercraft Universal Wobbel
    1/2 to 3/4 Chromie Adaptor
    12 PC Metric / SAE - 3/8 Drive - Allen Key Socket Set
    Snap on 3/4 to 1' Adaptor Impact
    Sunex 3/8 Impact Socket Set - Deep 5/16 to 1'
    Torch Tip Cleaner - Propaine / Oxy Etc
    blue point stepped feeler blade set for valve sets
    Home aid brake spring installer
    1/4 Drive - 12 Pt - 3/16 to 1/2 Chromies Craftsman
    1/4 Drive - 3/16 to 1/2 Deep Chromies
    1/4 Drive Shallow - 3/16 to 1/2 Chromies
    Deep 1/2 Inch Chromie 12pt - 1/2 to 1 1/6.
    Westward 3/8 to 1/2 Adaptor - Impact
    Mac 10mm - Long 3/8 Drive allen key socket - For Oil Pans
    Snap on Square Drive 3/8 Drive - to 5/16 - For Adjusting Most Slack Adjusters
    Mac tools Air Brake Adjustment Set
    SK 1 3/8 - 3/4 Drive Impact Socket
    Mastercraft 6pt Shallow impact Set 13mm to 27MM
    mac torque sockets 1/4 drive to 1/2 drive - t10 to t60 - 12 pc set
    Tap Sockets !!! GREAT for easy use of Taps! 8 PC - Snap ON
    Mac Tools Flank Drive Deep 1/2 inch impact sockets - 7/16 to 1 1/4
    Craftsman 7/16 to 1 1/16 - 12 Point Shallow Chrome Sockets
    3/8 Shallow - 6 and 12 point - 5/16 to 13/16
    mastercraft 6 point shllow impact - 1/2 drive - 7/16 to 1 1/16
    8 point 3/8 drive sockets 1/2 to 1/4 - For Brake work
    3 Drawers Full of various thing - Spray Paints - Lube's - Grease - Assembly Grease - Cutting Oil - Impact Oil - Rachet Grease - All Kinds of Stuff
    Junk Drawer Full of Various Switchs, bolts, nuts screws, wires, caps, plugs, flashlights, saftey glass's, flashlights, rulers, straight edges, measureing tapes,
    Snap on Gloves - Large - Good Cond still
    Snap on - Long Handel - Flex head 1/2 Drive Rachet - Metal Handel
    Snap on - Long Handel - Flex Head 3/8 Drive Rachet - Rubber Grip Handel
    Snap on - Norm Handel - Locking Flex Head 1/4 Drive Rachet - Metal Handel
    3/4 Drive Rachet - Craftsman
    3/4 Drive Exentions - Various Size's
    Varous 1/4 and 1/2 Exentions - Wobble Ends
    Snap On Racheting Screw Drive w/ Bits - Brand New
    Varous Mastercraft screw drive set - 20+ Pc's
    Mastercraft Oring Picks
    Blue Point Window Seal Installer
    Gasket Scaper - Razor Blade - Blue POint
    Snap on Gasket Scaper - Metal Edge
    Butt Connector Plyers - Crimpers - Snap on
    Weather pack Crimpers - Mac
    Auto Wire Strippers - Snap on
    1/2 snap on Toruqe Wrench
    3/8 Drive TOruqe Wrench
    8PC Snap on Screw Driver Set- Brand new
    Powerfist Dial Indicator Gauge + Base - Brand new
    Digital Caliper Brand new
    Blue POint Test Light - Straight Cord - Not Coiled
    Mac 4 pc - File Set. Brand new
    Blue Point Multimeter - Large Display.
    Various Home aid Jumpers / wires for various testing. Cat EMCS / Cummins ECM Pins etc
    Snapon 1/2 Composite Impact Almost Brand new - Best MOdel
    3/8 Mac Composite Impact w/ Swivel air terminal
    3/8 Mac Air Rachet - Pretty new
    1/2 - Air Drill - Blue Point
    1/4 Blue Point Air Rachet
    Air Hammer Bits - Flat-Punch / Chistel / Bushing Cutter
    Blue Point Air Hammer - Needs to Be rebuilt - In peice's ATM
    Blue Point Air Cut off Wheel / Grinder
    Blue Point 90 Deg Grinder / Cut off w/ Various Adaptors - Buffer Wheel / Wire Wheel / Cutter and Wrenchs for it
    Various Air Adaptors - For Testing Service / Emerg Brake - Glad Hands
    Tools Adaptors for Airing up Fan Hubs
    Air blow Gun x2 - Various sizes
    14 PC - SAE - Sunex - Offset Wrench's from 7/16 to 1 1/4
    Snap On Flank Drive Plus 10mm to 19mm - Long - Brand New
    Master Craft Stubby Wrenchs 7PC - 10mm to 18MM
    Craftsman Wrench Set - 7mm to 27MM - 17PC
    Snap On Flank Drive Plus 3/8 to 3/4 Wrenchs - Long - Brand New
    Mastercraft Stubby Wrenchs 3/16 to 3/4 - 7PC
    Racheting Mastercraft Wrenchs - Flats 5/16 to 3/4
    Mastercraft 1/4 to 1/4 Wrench Set
    HUGE Blue Point Channel Locks - Great for ripping off Fuel / Oil Filters With EASE
    Mac - Strap Wrench For Oil/Fuel Filters 1/2 and 3/8 Drive
    Rivet Gun Blue Point
    Blue POint Rubber Hose Cutters
    Mastercraft Plyer set - Various - Needle Nose / Cutters / Channel Locks / Long Need Nose / 40 deg 90deg Needle Nose Long's - 9PC
    Various Sized Cresent Wrenchs
    Various Sized Vise Grips
    Small Pipe Wrench Great for Exhuast Manifold Studs
    7Pc Snap on Snap Ring Set - 90 Deg. 45 Deg Straight - Various Sized Holes
    Homeaid Clutch Adjustment tool
    Rubber Mallet
    Snap on Dead Blow Hammer - Smaller
    Blue Pt Ball Peen Hammer - Snaller
    Blue POint Mini Sledge Hammer
    Various Homeaid Punchs Great for Beating things
    Mac 1/2 - 1 FOOT LONG! Punch - Also Great for Beating on Things
    Snap on 4PC - Heel Bar Set - Brand New
    Snap on Roll Pin Punch Set - 8PC
    E-z Out Set - Snap on - 4PC LEFT HAND
    Snap On Punch / Chistel Set - Various Size's - 10PC
    Burrs / Cutters - Snap on - 4 PC SET - Very new
    Snap On - Electronic Weather Pac Terminal Kit - For Taking apart weather pack plugs / Various Terminals - Pulling the terminals out
    Mac 3 Pc - Pry Bar Set - Oranage - WITH METAL END CAPS!!! So u can beat on them!
    Im Sure theres alot of Stuff ive forgotten too, or didnt list... Almost everything here is under warranty - besides maybe the Air Tools.
    The Snap on 1/2 Inch Impact Is Under Warranty Still
    All the Sockets Are under warranty w/ mac/snapon/craftsman/mastercraft etc
    Everything should be covered by the maunfac as far as warranty.
    Asking 9500.00 OBO!!
    EMAIL ME @ [email protected]
    !!!!!!! NOT PARTING OUT - SELLING AS A SET!!!!!!!! SELLING AS A SET!!!!!!!!!!!!!!!!
    FOR PICTURES GOTO: http://s856.photobucket.com/albums/ab129/snapfx/
    Or EMAIL ME IF U WANT MORE PHOTOS!!!
    Im a 3rd Year Heavy Eqipment Tech, Reason why im selling, im going back to school to take something new.. Im done with the trade
    Theres Not much you will need, besides a few odds and ends for the trade.
    Otherwise this will be a GREAT Set of tools for any Mechanic in the HET Trade
    Edm
    yur moma
    btw this is in edmonton.. im not shipping.. sorry... pickup only
  1. F/S Some Snap-on and Mac tools and new brad nailer
    By 427 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-10-2009, 04:21 PM
  2. WTB: Snap-on tools
    By Sharpie in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-24-2009, 12:40 PM
  3. Need a snap-on tools rep's phone #
    By 78si in forum General Car/Bike Talk
    Latest Threads: 10-14-2008, 07:49 PM
  4. Replies: 0
    Latest Threads: 10-08-2008, 04:15 PM
  5. Matco toolbox/snap on tools like new and cheap!!!
    By Rui M in forum Automotive Parts
    Latest Threads: 01-13-2007, 11:58 PM
