What causes this? Worn mount? Clutch nearing its life expectancy?
possible worn/broken mount, or glazed flywheel surface/fluid on flywheel
illmotion: http://www.illmotion.com
push or pull type?
Haltech Factory Trained and Elite Certified / AEM EMS and Infinity Factory Trained Tuner / ECUTek Factory Trained Tuner for FRS-BRZ and R35 GTR / HKS Pro Tuner / Apexi Power Exel Certified Tuner
Proud to be a "hater" that defends Authenticity
hot spots on the pressure plate and flywheel from too much riding, or too much power and too little clutch. Could also be from oil leaking on the clutch from a leaky valvecover
Originally posted by InRich
I think it should be a MINIMUM payment of 20% across the board for any kinda house. Who can't save 20% nowadays, just stop eating out, drive a japanese shit box, and save, its not hard.. have some fucking discipline. Half you niggers shouldn't even be in the houses you live in now.
we can't all drive X5Ms
Not revving it enough on takeoff, if it's a performance clutch and not a worn out stock replacement.
What do you mean?Originally posted by JZS_147
push or pull type?
Im thinking hotspots too, as it just started doing it and I've been driving it the same way. car does not have any oil leaksOriginally posted by 71/454
Not a performance clutch as far as I can tellOriginally posted by Sentry
If it's hotspots and they aren't too terrible they can go away after a while of proper driving.
also, it could be your rear main seal leaking oil into the tranny. I had the same issue when I had my civic a few years back, and it some of it got on the flywheel...
Hot spots on your clutch as mentioned. I had a car like that before, it just got worse when it got cold out because of the metal reacting to the cold. It's from resting your foot on the clutch while driving.
Originally posted by Go4Long
you do realize this is the internet right? lolOriginally posted by rob the knob
then you will be happy if you fine place in liveOriginally posted by blitz
It's the same as rotors when they shake, the end result is hot spots on the clutch. These are areas where there is more material than other due to run out on the flywheel surface.
The cause of this is due to contaminants on the flywheel or the clutch disk, usually resulting from not prepping the surfaces correctly. It can also be caused by excessive slippage when engaging the clutch, as mentioned above by resting your foot on the clutch pedal.
Slow engagement of the clutch with low RPMs is the best thing you can do for your clutch, engaging with only releasing the clutch out and not using any gas dramatically reduces wear on your clutch.
Unfortunately at this point you need to remove the flywheel, have it resurfaced and possibly replace the friction disk and pressure plate.
