Hot Water Tank, no hot water. - Beyond.ca - Car Forums
Results 1 to 13 of 13
Thread: Hot Water Tank, no hot water.
    Nov 2003
    Default Hot Water Tank, no hot water.
    Well 2 days ago I woke up to an icy cold shower.
    Took a look at my hotwater tank and the pilot light had went out. I tried to relight it, but as soon as I released the red override button the flame goes out.
    I replaced the Thermocouple thinking that was the issue, and it has the same problems.
    Its 2002 Bradford White 40Gal Natgas water tank
    It takes a huge man to stand in cold water and wash... as it turns out.. i am not that manly.
    I need to fix this asap.
    Any suggestions?
    EDIT: Forgot to mention im fairly broke, so I cant afford to replace the entire thing.
    Red Deer, AB
    The only other thing I can think of, since you have replaced the thermocouple already, is that there is some kind of dirt/debris or blockage in the gas line...
    ...unfortunately, it will require a service call to diagnose... I am not too sure what else it could be.
    Only 15min from Aspen!
    Nothing interesting anymore
    Default Re: Hot Water Tank, no hot water.
    This may seem like a stupid question, but there are some people who don't know better... you are holding the button down long enough to warm up the thermocouple, right?
    TRD Pro
    When I had to replace my thermocouple, I also had to hit a 'Master Reset' button.... did that and it worked fine.
    Maybe call the manufacturer? most will have a hotlline...
    Aug 2005
    Calgary Alberta
    Default Re: Re: Hot Water Tank, no hot water.
    In my experiance it can take up to 10 minutes to get everything hot enough to keep the pilot light running. I have seen people use a blow torch in there to help speed up the process but I am not sure if that is recommended practice. Might be worth a try before spending any money on it.
    Nov 2003
    Yea i have held the override down for 10 minutes before and it still doesnt work.
    When i am holding the button down, the pilot is a nice blue strong flame, plus i have cleaned both the pilot and the air holes, etc on the unit.
    I tested the termocouple with my multimeter, and its working fine.
    After talking with a plumber buddy of mine, he thinks its the Gas control vavle, or the ECU has been tripped on it. Which is a one time use deal.
    There is no master reset on my unit.
    Cochrane, AB
    Trucks
    I tested the thermocouple with my multimeter, and its working fine. [/B]
    If you get more than 15mV open or 3-5 mV closed thermocouple is good and change the valve.
    Oct 2004
    AB/NS
    Thanks for the compliment...
    Nov 2003
    It gets tiresome after a few times. Sure wakes you up tho.!
    Hopefully my new part isnt much more than $100.
    Nov 2003
    Installed a new gas valve, and the pilot stays on now, and it fired up and started heating water.. Hurray!
    $125 at Emco btw.
    Jan 2005
    YZ250
    Props for doing it yourself
    Dec 2006
    Lease
    Wow nice work tackling this yourself.
    You could had boiled hot water and took baths.
    Nov 2003
    Yup, turned out to be fairly easy, but im quite handy so it helps out.
    But i did enjoy wrenching at it for a while, im pretty sure the name of the guy that assembled my unit was "Superman".. or at the very least "He-Man"
  1. Please service my Hot water tank-no hot water!
    Latest Threads: 12-30-2012, 09:29 PM
  2. FS: Hot Water Tank & StainLess Steel Dishwasher 4sale
    By magic99 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-27-2008, 10:58 AM
  3. Hot water tank drain valve.
    By frozenrice in forum General
    Latest Threads: 01-29-2008, 08:16 PM
  4. hot water tank
    By Sorath in forum General
    Latest Threads: 12-26-2007, 03:42 AM
  5. Need hot water tank repairman
    By gonefishing in forum General
    Latest Threads: 06-20-2007, 12:25 AM
