Alternative to deadlift?? - Beyond.ca - Car Forums
Results 1 to 8 of 8
Thread: Alternative to deadlift??
    Feb 2003
    DT 780
    LEXUS LX470
    Default Alternative to deadlift??
    I've had lower back problems and am wondering if there are some exercises that hit the same muscles as a deadlift??
    right now my routine is lacking in the deadlift and I believe this is hindering my weight gain...
    I can do squats fine but the deadlift motion seems to aggravate my lower back.
    Tap, Rack, BANG!
    Jun 2007
    11 STI
    try using a belt. It will help
    HABS...road to 25
    Mar 2009
    TL
    i had the same problem and my doctor said my lower back muscles were extremely deconditioned (because i was sitting in a chair all day). Your doctor may recommend physio if your back problems are because of the stabilizing muscles.
    Jan 2007
    Toyota Tercel
    When I hurt my back and then knee, I revamped my workout to mostly weight training exercises with a stability/balance aspect.
    Instead of plain deadlifts, I did Single-Leg Romanian Deadlifts and deadlift on a BOSU half ball.
    You won't be able to do much weight at the start (I started out with just body weight) because your stabilizer muscles aren't used to it but eventually I worked up to using dumbbells and my back got stronger and better.
    http://www.menshealth.com/powertrain...n_Deadlift.php
    The romanian deadlifts are also good for improving your hamstring and glut flexibility which might be a cause of your back pain.
    Oct 2003
    How is your technique? DLs shouldn't hit the lower back primarily, the glutes/hams should bear the load. My experience is that my lower back gets taxed more from high volume squats as the lower back has to stabilize the weight on my back.
    If you gym has one, try glute/ham raises, and back hyperextensions. Also, don't neglect the abs, as strong abs = strong back.
    heloc that shit
    TL
    yes/no
    It depends on the actual DL stance imo. Conventional vs Sumo.
    There is no alternative for the deadlift. The posterior chain and strong core, helps you with this lift. If you can't do too much weight on it, then be safe. Work up your posterior chain and the dull pain will start to go away. If the pain is sharp, then there is something wrong...
    Jan 2003
    canada
    g2 teg
    no substitution. /end thread.
    Mar 2005
    I would have to agree with this. There is no substitute for bench/OHP/squat/DL
  1. deadlift trainer
    By TurboD in forum Body Building / Weight Training
    Latest Threads: 07-02-2009, 10:19 PM
  2. Deadlift 101
    By Darkane in forum Body Building / Weight Training
    Latest Threads: 05-02-2009, 05:08 PM
  3. LF: used hex deadlift bar / ab bench
    By gmoney82 in forum Fitness & Sports Equipment
    Latest Threads: 12-10-2008, 05:10 PM
  4. Any Suggestions for an Alternative to Steel Braided Lines
    Latest Threads: 09-24-2003, 07:01 AM
