01' Integra - Fault Code Running Rich - Help! - Beyond.ca - Car Forums
Results 1 to 2 of 2
Thread: 01' Integra - Fault Code Running Rich - Help!
    Jan 2006
    Default 01' Integra - Fault Code Running Rich - Help!
    Timing belt just done, possibly related?
    Fault Codes:
    P0170 - Fuel Trim Malfunction Bank 1
    P0172 - Running Rich
    First 02 sensor fluctuated between 0.1V and 0.9V
    Second 02 is pretty steady at 0.8V
    Long Term Fuel Trim is always in Negative Range.
    Symptoms:
    Vehicle shudders around 2500rpm in the lower gears.
    High Fuel Consumption
    Tried the following:
    Cleaning IACV
    New Fuel Filter
    New Spark Plugs (Properly Gapped w/ New Wires)
    Added Fuel Injector Cleaner
    Cleaned MAP Sensor
    Cleaned Intake and Throttlebody with Carb Cleaner
    Anything I might be missing here?
    I would appreciate some input on which direction I should take with the troubleshooting?
    -Should I investigate implications from the timing belt change?
    -Do you guys think it might be a fuel system related thing ie. Fuel Pressure Regulator, Fuel Pump, etc.
    -Vacuum leaks??? O2 Sensor Faulty???
    Apr 2007
    boosted crvtec civic
    Default Re: 01' Integra - Fault Code Running Rich - Help!
    Fault Codes:
    Symptoms:
    Cleaning IACV
    New Fuel Filter
    Cleaned MAP Sensor
    try testing your fuel pressure. could be that your fpr is stuck and the mass amount of fuel is bogging it down at lower rpms where at higher rpms it can be burnt off.
  1. 01' Integra - Fault Code Running Rich - Help!
    By bbhomie in forum General Car/Bike Talk
    Latest Threads: 11-30-2009, 12:09 AM
  2. Peake FCX-II BMW fault code tool
    By Kaos in forum Alberta BMW Owners Club
    Latest Threads: 09-02-2008, 09:13 PM
  3. Looking for a Fault Code Reader and a SRS Code Reader
    By j0nblayz in forum Alberta BMW Owners Club
    Latest Threads: 03-05-2005, 09:37 PM
  4. Help running too rich.
    By DodgeMan006 in forum Mechanical
    Latest Threads: 03-04-2005, 06:14 AM
  5. a/f running too rich???
    By sml in forum Mechanical
    Latest Threads: 06-28-2003, 08:28 AM
