Tow Rope/Tow Strap Recommendations - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: Tow Rope/Tow Strap Recommendations
    Oct 2006
    BMW
    Default Tow Rope/Tow Strap Recommendations
    So with this snow, been looking at getting a tow strap/tow rope.
    I don't quite understand the rating of the tow ropes.
    I looked at one at it has:
    6,800lbs breaking strength
    Loads up to 2267lbs.
    So is this rope good enough to tow a car out of a snow bank, my x5 has a curb weight of like 4900lbs, so is this rope strong enough to use to pull a car?
    Oh and any recommendations on where to buy decent ones, the one I am referring to is from Canadian Tire.
    um... you have to factor in serveral things such as the resitance resulting in how stuck the vehicle is, inclines etc..
    I use a mix of tow "straps" from Princess Auto, which I can't exactly remember the raiting for, but was quite a bit strong in breaking strength.
    Don't buy the ropes, they have no give, nor the ordinary straps... get the ones that have some elasticity to them, otherwise you dangerously risk breaking off tow points.
    edmonton ab
    if you get a tow strap, get a tow sling. Its a springy stretchy tow strap that when you giver shit, it will lengthen the strap then compress back and sling the vehicle thats stuck, out. i would get one thats ALOT stronger than that, think about how much force your vehicle gives out horizontally. ive snapped many a strap.
    If you go to PA, they have like 6 different ones, i got the third strongest and it hasnt snapped yet soo.
    Originally posted by Gabe182
    We need nips! and they better not be huge!
    Sep 2005
    Word - PA is the place to go.
    6,800lbs breaking strength sounds quite low - I do believe mine is somewhere closer to 15,000lbs.
    Red with stripes and a shitbox truck
    Go to Princess Auto and get the biggest thickest tow sling that you can find. I picked up an almost 6" thick tow sling that we use for 4x4ing. It's rated to like 25,000lbs, but the PA slings are pretty shitty so I'd recommend buying the biggest one you can find. No sense buying a small one and having it break on you. I've heard too many horror stories of slings going and taking someone's head off. Also, whenever winching, throw a blanket/coat on the sling in the middle before you put tension on it. Just acts as a dampener if the sling lets go and will direct the force downwards.
    Feb 2009
    91 xj,69 Chevelle.93Stang
    I'll give another nod for Princess Auto. There are several load ratings for each strap. A 2-3" is all you will need for the occasional tug out of a jam. Should be in the $50-$60 range. I would definately avoid ropes/straps with hooks on the ends. They could break and hurt/kill someone or cause damage to the vehicle pulling you out.
    Also consider how you are going to attach the strap to your vehicle. Try not to slip the looped end over a ball on the hitch. They tend to slip off.
    Use It up, wear it out, make it do..or do without
    Default Re: Tow Rope/Tow Strap Recommendations
    The rating means that the rope has been tested to 6800 lbs and it didn't break. they reccomend that you don't put more than 2267 lbs force on it in normal use. That give you a safety factor to account for a) wear b) shock loding and c) accidental overloading.
    Tow straps and ropes can be deadly when used incorrectly, so they put a big safety factor in the ratings, and you should adhere to those saftey factors. Don't skimp out on tow equipment, because it can and does kill people every year.
    Here are my suggestions for towing stuck vehciles.
    - Get a stap that has some elasticity in it. It's easier on the cars, and it's more effective
    - get a strap that is rated for much higher than you will ever see. at least double your cars mass.
    - use proper shackles at each end.
    - put something heavy over the middle of the rope if you can, like threading it through an old tire, or a duffle bag full of stuff. That way if it does break, that will absorb a lot of the energy and protect the people at each end.
    Good luck!
    Pizza preferences are more polarizing than politics.
    Oct 2004
    AB/NS
    I pull quite a few ppl from the ditch every winter in my travels.. I also have a PS strap, 3" maybe.. I've used it around the farm too, it works great. I think it was around 60$.
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Back in the day, i used to just take a tie down strap from my rig, and get the wife to sew a loop in each end. worked great.
    mind you, the company paid for them, so i got no idea how much they cost.
    But yeah, if you are off roading, get the biggest you can. if you are never going off road, but just tugging people out of the ditch, a 10k lbs sling should be fine. shackles are a great idea, and just make sure the sling will stay attached to a vehicle, rather than flying off.
    as for putting something over the line, while a great idea in theory, you kinda need to know where the fail point is going to be to make it effective, and put something on each side of that fail point. the only instance where it would work, is if the fail point is one of the vehicles themselves. there should only be 2 people around anyway, 1 in each vehicle, and if the sling snaps, they are protected by the vehicles. if someone is standing close enough to get hit, well i call that darwinism.
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
    Oct 2006
    BMW
    Cool, thanks for the info, will check out PA soon.
    I disagree on two points
    1) regardless of where the failure is, it's the longer peice of rope/strap that will have the most energy, and if the energy absoring device is in the middle, the long peice will go through the middle.
    2) people in vehicle aren't protected from flying shackles, or god forbid, chains and hooks. Those can and do go through windshields pretty easily. I agree that bystanders should be well back and perpendicular to the tow strap/rope to avoid any danger if it snaps, although that kind of common sense isn't common, it seems.
    Nowhere
    Unemployment Line
    Sierra, RDX
    I decided to go with overkill for almost all my gear, better out a few more buck but coming home intact.
    I use 30,000lb straps from MM, a 10,000lb tree saver, ARB 9,000lb snatch block and nothing less than a 3/4" shackle. No strap with hooks EVER gets attached to me or to someone I'll be helping.
    By my estimation my winch will seize up before anything fails. If I need to to anything bigger than what an 8,000lb winch with snatch block or a 6500lb tow rating will do, I shouldn't be doing it.
    Jan 2010
    NW-Bowness
    Loud ass Dodge-deal with it
    It's better to go too much than not enough with a tow strap. I'd be more worried about pulling anything with an X5!
    Get something like this. http://www.amazon.com/Grip-Heavy-Dut.../dp/B000G6M5HO
    With a 15000 lb rating your tranny will go before the strap will!
    Unemployment Line
    Sierra, RDX
    I think it has been mentioned but you should never use a tow strap for a recovery. Reason being, there is little to no elasticity in the strap. Get proper recovery straps that had stretch to them, 2x the max vehicle weight you will be recovering should be good.
    Jan 2007
    CALGARY
    3x30 is plenty.
    Sometimes you have to take a chance, whether that be on someone, or something!
  1. FS:Js racing front tow hook/ benin rear tow hook
    By Lucky97 in forum Automotive Parts [Aero/Styling/Interior]
    Latest Threads: 10-04-2008, 07:40 PM
  2. losing weight through rope skipping
    By kaishen in forum Health and Fitness
    Latest Threads: 04-29-2007, 09:10 AM
  3. jumping a rope
    By Grip172 in forum Health and Fitness
    Latest Threads: 12-13-2005, 03:25 PM
  4. Bungee Tow Rope - Where to find in calgary
    By psxlady in forum Trucks, 4x4 and Offroading Zone
    Latest Threads: 01-13-2005, 03:24 PM
  5. at the end of my rope
    By Teabag in forum Mechanical
    Latest Threads: 02-18-2004, 12:46 PM
