NEED HELP B16A swap into 1992 Integra - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: NEED HELP B16A swap into 1992 Integra
    Oct 2006
    1098S
    Default NEED HELP B16A swap into 1992 Integra
    Hey just doing the engine swap on my 1992 Integra Base. Ran into a couple obstacles.
    FYI
    We are re using the ls transmission with the B16A
    The car and motor are both OBD1
    Does anyone know if this is an aftermarket intake manifold on the B16a? Here is a picture of the B16 manifold beside the old LS one (which is still on the motor). There are several vaccum inputs on the old LS manifold that aren't present on the new B16a manifold. Any input here would be appreciated.
    where are these vaccum lines supposed to hook up on the new motor?
    Originally posted by S2K2
    Haha I am pushin more hp than your car will ever see I have carbon fiber u don't...
    Originally posted by Sebasshole
    But give her a thumb in the eye just to be safe.
    Nov 2005
    Hondas
    That is just a plain jane sirII b16 intake manifold.
    The extra lines you picture last are off the MAP sensor and the purge solenoid. the teg is using an obd0 style MAP.
    an obd1 throttle body should have a MAP sensor on it, and yours does not, so you will need to find a way to get vacuum to the firewall-mounted MAP sensor.
    the two "canister" looking things are the purge solenoid and you can leave it unhooked IIRC.
    Oct 2006
    1098S
    Sorry that should be a question. Is the bottom line for the MAP?
    Sep 2005
    1990 240sx
    take off the round solinides, throw in garbage. square box is map, get rid of vacuum line clusterfuck hook one line from map up to engine vacuum. then your good to go.
    Nov 2005
    Hondas
    you've got it.
  1. FS: b16a dizzy and b16a PR3 ecu
    By Foreign1 in forum Automotive Parts [Engine Electronics]
    Latest Threads: 01-27-2008, 01:30 AM
  2. B16A plus auto to manual swap in 91 civic help.
    By sean84 in forum Performance Modifications
    Latest Threads: 04-11-2005, 06:16 PM
  3. 94 civic si coupe swap: B16A G1 or B16A G2
    By Importworld in forum General Car/Bike Talk
    Latest Threads: 04-04-2005, 05:38 PM
  4. B16a Swap into 1990 Integra
    By SanmaX42 in forum Mechanical
    Latest Threads: 06-30-2004, 05:16 PM
  5. H22A swap into an 94 integra?
    By Speed_RaSiR in forum Performance Modifications
    Latest Threads: 09-03-2003, 03:43 PM
