So I finally have myself a proper DSLR, but after just over 2000 shots I started noticing a consistent stuck sub-pixel on the CMOS sensor in my 450D. I just got into photography within the last year and am not an expert by any means, and wanted to see if perhaps this is just a usual "luck of the draw" situation or whether it is something worth redeeming warranty for. In raw it turns up as a solid green pixel, whereas after a conversion to JPEG it turns into a white star over a few pixels..
Examples:
Upper right:
Upper right:
What can I do? I've heard about some sort of "pixel-fixing/remapping" feature that Canon has, but I am having trouble finding it within any of my included programs or on the Camera itself..
Secondly, I have been using a UV filter on one of my lenses as a cheap lens protector. After having used it on my 18-55 for a while I have noticed intensified lens flare as well as random "blooming" of some sort in my photos. As soon as I take it off, the pictures lose the horrid glare marks - so what is causing it? I wasn't under the impression that this was a usual side-effect, but I am guessing that light is somehow bouncing between the filter and the outermost lens.. My polarizing filter (HOYA - Japan) doesn't do this at all, however is it because my UV filter (CANON - USA built) is of horrid quality?
Example:
You can also spot the pixel issue in the middle of the upper 1/5..
Thank you kindly for any help!
