$50... like new!! Pickup in NE only!
http://www.memoryexpress.com/Product...6%28ME%29.aspx
Product Info
Kingston® ValueRAM® delivers the same reputable, high-quality Kingston memory modules you've known for years at competitive prices for the white box market. Kingston ValueRAM modules are designed and validated to meet or exceed industry specifications, including JEDEC and the specification set forth by chipset, motherboard and system manufacturers worldwide.
ValueRAM's KVR800D2S6/2G is a 256M x 64-bit 2GB (2048MB) DDR2-800 CL6 SDRAM (Synchronous DRAM) memory module. The components on this module include sixteen 128M x 8-bit DDR2-800 SDRAM in FBGA packages. This 200-pin SODIMM uses gold contact fingers and requires +1.8V.
Features
* PC2-6400 DDR2 800MHz
* CL=6 CAS Latency
* 200-pin Unbuffered SODIMM
* 1.8V Operation
* Comprehensive testing
* Top-quality Components
* Superior quality at competitive pricing
* Lifetime warranty
Specifications
Capacity 2GB
Memory Type DDR2 PC2-6400
Speed 800MHz
Timing CL=6
Voltage 1.8 V
Configurations 256M x 64-bit
Pins 200-pin Unbuffered SODIMM
Head Spreader N/A
