Due to still being in finiacial problems I must sell my camera
High end Camera for sale
Comes with Everything including a camera Bag
*due to finicial problem I must sell my camera*
Will sell without the SD card for $250.00
With 8 gig Ultra 2 card for $300.00 firm
>>>>> If interested call me at 403-771-3263
Coolpix P5100
Product
Information
Coolpix P5100 Type of camera: Compact digital camera Effective pixels: 12.1 million CCD: 1/1.72-in. CCD; total pixels: approx. 12.43 million Image Size (pixels):
4000 x 3000 (12M)
3264 x 2448 (8M)
2592 x 1944 (5M)
2048 x 1536 (3M)
1600 x 1200 (2M)
1280 x 960 (1M)
1024 x 768 (PC)
640 x 480 (TV)
3984 x 2656 (3:2)
3968 x 2232 (16:9)
2992 x 2992 (1:1)
ISO Sensitivity (Recommended Exposure Index): ISO 64,100, 200, 400, 800, 1600, 2000, 3200, Auto (auto gain to ISO 64 to 800 equivalent) Lens: 3.5x Zoom-Nikkor lens Focal Length: F=7.5- 26.3mm (35-mm [135] camera-format equivalent: 38-123 mm) f/-number:
f/2.7 - 5.3
Construction: 7 elements in 6 groups Digital zoom: Up to 4 X (35-mm [135] camera-format equivalent: 492 mm) Vibration Reduction VR Optical Image Stabilization Autofocus (AF): Contrast-detect AF, Multi area AF Focus range (from lens):
30cm (1 ft.) - ¡Ä (W); 70cm / 2ft. 4in -¡Ä (T)
Macro close-up mode: 4cm (1.6 in.[wide angle zoom position]) - ¡Ä
Focus-area selection: Face Priority, Auto (9 focus areas), manual (99 focus areas), Center LCD Monitor: 2.5in., 230,000-dot, wide-angle TFT LCD with anti-reflection coating and 5-level brightness adjustment. Approximate frame coverage: Shooting mode: 97 % horizontal and 97 % vertical; Playback: 100 % horizontal and 100 % vertical Storage Media: Internal Memory (approx. 52MB); SD (Secure Digital) memory cards File System: DCF, Exif 2.2, and DPOF compliant File formats:
Compressed: JPEG-baseline-compliant; (Fine 1:4, Normal 1:8, Basic 1:16)
Movies: AVI; Sound Files: WAV
Exposure Metering System: 256 -segment matrix, center-weighted, spot, spot AF area (with support for 99 AF areas. Exposure Control Programmed auto exposure with flexible program, shutter-priority auto, aperture-priority auto, manual, exposure compensation (-2.0-+2.0EV in steps of ¨÷ EV), Auto bracketing Exposure Range: W: +1.0 - +17.5 EV , T: +0.9 - +16.4 EV Shutter: Mechanical and charge-coupled electronic shutter Speed: 1/2000s - 8s Aperture: 6- blade Iris diagram Aperture Range: 10 steps of ¨÷ EV Self-timer: 10 or 3 second selection Built-in flash Range (approx.):
W: 0.3m - 8m / (1ft. - 26ft. 2.9in.)
T: 0.3m - 4m / (1ft. - 13ft. 1.5in.)
Built-in flash sync method: Sensor flash system Accessory Shoe ISO 518 hot-shoe contact with safety lock Sync Contact X-contact only I/O terminals: Audio / Video output; digital I/O (USB) Interface: USB Video Output: Select from NTSC or PAL Supported Languages: Czech, Danish, German, English, Spanish, French, Indonesian, Italian, Dutch, Norwegian, Polish, Portuguese, Russian, Finnish, Swedish, Chinese (Simplified and Traditional), Japanese, Korean, Thai, Turkish Power Sources:
One EN-EL5 Rechargeable Li-ion rechargeable battery (included)
EH-62A AC Adapter (sold separately)
Battery Life:
Approx 240 shots* with fully charged EN-EL5 Lithium-ion rechargeable battery on CIPA standard operating at an ambient temperature of 23¨¬C (73¨¬F)
* - Based on Camera and Imaging Products Association (CIPA) standards for measuring the life of camera batteries. Measured at 23¨¬ C (73¨¬F) ; zoom adjusted with each shot, flash fired with every other shot, image mode set to Normal (4000x3000). Battery life may vary depending on shooting interval and length of time menus and images are being displayed.
Approximate Dimensions: Approx 98 x 64.5 x 41mm (3.9 x 2.5 x 1.6 in) excluding projections. Approximate Weight: Approx 200g (7 oz) (without battery, memory card) Operating Environment Temperature: 0 - +40¡ÆC (+32-104¡ÆF) Operating Environment Humidity: Less than 85% (no condensation) Supplied Accessories*
USB Cable UC-E6, Audio / Video Cable EG-CP14, Rechargeable Li-Ion battery EN-EL5, Battery Charger MH-61, Strap, Software Suite CD-ROM
* - supplied accessories may differ by country or area
Optional Accessories*
AC Adapter EH-62A, Wide-Angle Converter WC-E67, Telephoto Converter TC-E3ED, Adapter Ring UR-E20, Speedlight SB-400, Speedlight SB-600, Speedlight SB-800
