I have an external hard drive minus the drive that i dont need anymore.
Here are some specs:
Windows® PC requirements
Pentium® II-class or equivalent processor or higher
Microsoft® Windows® 2000 Professional / XP Home / XP Professional / Vista™
(Check back for updated operating system support information)
Must meet recommended RAM requirements for your operating system
(See your OS manual for details)
When using an add-in USB controller card, must meet requirements for the card
USB 2.0 host connection or controller for USB 2.0 speeds
Microsoft Internet Explorer 5.0 or higher or Netscape ® 6.1 or higher to view User's Manual
Mac® requirements
Mac® G3 or higher computer with built-in USB connection*
Mac® OS X version 10.1.5 or above
Safari 1.0 or higher to view User's Manual
*NOTE: Drive performance will be slower connected to USB 1.1.
Drive Attributes
Interface
USB 2.0 (backward compatible with USB 1.1 at reduced speeds)
Capacity (SATA)
1TB
750GB
500GB
320GB
250GB
Format
FAT32 (default)
Weight
1.26 kg (2.78 lbs)
(weight varies slightly depending on the installed hard drive)
Dimensions
Length: 222 mm (8.75")
Width: 121 mm (4.75")
Height: 34.9 mm (1.37")
External Power Supply
Input Voltage:
90Vac - 264Vac
Output Voltage:
12VDC +/- 6%
Max current:
2.0 amp
USB 2.0 transfer rate
480Mbits/s
Rotational Speed
7200 RPM/5400 RPM
Memory Cache
8MB or greater
Looking for $60 for it. EMT prefered
