Good day all,
Having a problem with my DEI remote starter. Its the 2 button keypad, no frills. Pressing the #1 button will only flash the park lights, once, then when I press it again, two flashes.
I have tried the toggle switch and get the same results. I checked the pin under the hood and that is intact as well. I read where disconnecting the negative battery terminal may reset the system. Don't know if this will help or not.
If you have had this problem or have a solution, it would be very much appreciated.
Thanks
Craig
