car wont stop puttering! - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: car wont stop puttering!
    97 Ls/Vtec ..95 Pathfinder
    Default car wont stop puttering!
    ok im sitting at lights and stuff and the car wont stop bouncing from 1400's - 900's/rpm its so loud and is really annoying what is the problem? im taking it in for a tuneup on friday i hope that fixs it.
    anyone had this happen?
    A$$
    The depths of despair!
    Anything topless.
    I had that happen to me on two different occacions and I've managed to solve both of them. The first time it was because I performed the throttle body coolant bypass. this is where one re-routes the coolant line so it does not go into the throttle body. It did help with the temp of the air going into the engine but it caused some pretty erratic idling. It didn't happen all the time, but every once in a while. I changed it back to stock.
    As for the second time, I disconnected the vaccum line that runs into the cold start valve. It's a line that runs from a little solenoid inbetween the intake manifold and valve cover and the vaccum line runs to the intake piping. I have this disconnected and it was not a problem, the problem was when I hooked it back into the charge piping and then it started bouncing again but a couple of revs cured it and then I just disconnected it again. No problems yet (knock on wood, hahaha)
    Well, hope this might help.
    WTF!! I am a moderator!!
    The Gutter
    UCF20/R35
    And I do think that Ryan did do some free mods to the prelude?
    Originally posted by rage2
    05 Chrysler 300
    nope. not on that motor
    Jul 2002
    more likely than not it is the spark plugs.....
    Built not Bought.
    well when ibought the car it would do it for about 2 min than once it was warmed up it would stop and not do it again till i left it overnight, it has just started this in the last week.
    its going into calgary honda tomorrow anyway hopfully they can fix it, i remember ledgendboy telling me somthing but i dont remember
    A$$
    Jul 2002
    if it smooths out after the higher rpms then i am pretty sure it is the spark plugs.....if you are a do it urselfer i would jus go shell out the 30 bucks for the spark plugs and do them urself to see if it makes a diff....u proly need to change them anyways and plus, unless u have a warranty plan u wont have to pay all the $$$ calgary honda will charge u with "what is wrong" with the car
    Built not Bought.
  1. Pit Stop Challenge!!!
    By Ben in forum Events and Meets
    Latest Threads: 08-01-2002, 09:40 PM
  2. Stop changing the channel, b*tch
    By bol in forum General
    Latest Threads: 06-18-2002, 11:11 AM
