polished concrete floors, has anyone done this? - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: polished concrete floors, has anyone done this?
    **SEQUOIA**
    Default polished concrete floors, has anyone done this?
    I recently ripped up the carpet and my basement and now I am left with concrete floors. I was planning on putting some cheap laminate flooring however the concrete look is growing on me. I have a friend who has a condo downtown and he has polished concrete floors and it is absolutely beautiful. Has anyone ever done this before? If so, how much did it cost you?
    Thanks,
    My uncle has a basement that must be 2,500 sq. ft., he says it is really hard to keep the floor in a state of shine. Something about the floor cleaning solution, most leave streaks and some a cloudy film. I don't think he has it sorted yet, and it is a pet peeve of his. So, I would ask around about the cleaning process, my aunt says it is a real pain, she wants to cover the floor.
    IMO the floor looks great, heated as well, I think there is a solution and would do my entire place in polished concrete (heated).
    Stay away from the cheap flooring, really it is garbage, wears badly and feels like crap underfoot. I have been in a few houses with cheap laminate flooring and it shows. Having said that, do not go cheap on the foam layer under the floor, it makes a difference if you need to go with the laminate floor. Polished concrete with a coating ought to be far cheaper, but rather cold if not heated.
    Jun 2004
    90 DB1, 03 RL1, 07 YK1
    You can get the stuff and do it yourself.
    Northland Construction carries a product called Wetlook Sealer. A 5gallon pail is around $105.00 and you just roll it on with a paint roller. IIRC a pail will cover about 800-900 sq.ft.
    If you end up going there, just to make sure the sealer that I'm recommending is the right stuff, you can ask them for more information to make sure that it'll give you the desired result.
    http://www.northlandconstruction.com...t.php?pid=2691
    They have a large line of product that may suit your needs better depending on what kind of look you are going for.
    Jul 2005
    watching this thread because I have wanted them for years. love them, they look fantastic.
    Sep 2005
    Reality
    Is fun!
    For cleaning try a steam cleaner/mop, maybe?
    72 Virgins
    Applying a sealer is not the same as actual concrete polishing which uses a series of finer grit to achieve the polished finish. A floor with sealer will wear down and become dull, whereas a floor that has been polished will be durable and remain polished without applying anything to the surface.
    Originally posted by Spoons
    I can't even count the amount of times I took a pill with meth, heroine, speed, you name it laced with it. You gotta be careful.
    Jun 2004
    How exactly do you polish concrete without applying something? Just like wood or fiberglass or even metal you can't just polish it without some sort of finishing product (ie rubbing/polishing compound). I'm interested in knowing how it can be done as I'm working on a project that could benefit from such a process. Let me know. Thanks.
    Plenty of videos on youtube.
    It is a PITA (Pain in the ass) project, now I know why so few homes have polished concrete floors:
    Still worth it though!
    Sep 2002
    Beyonds Official Realtor
    www.jordanlotoski.com
    Hope you have in-floor heat cause your gonna have one chilly basement.
    "BEYONDS OFFICIAL REALTOR"
    Instagram @jordan_empirewest
    Ranked #1 RE/MAX Professionals (2013-2022)
    Ranked Top 100 Re/Max agent Western Canada (2013-2021)
    Check out my mobile app
    goagent.ca/98F1B2F9
    Here is all we need to know about concrete floors:
    http://www.concretenetwork.com/concrete/polishing/
    You can stain concrete floors as well, this is the treatment I have seen before, it has a great WOW factor:
    http://www.concretenetwork.com/staining-concrete/
    There is a section on the website regarding ceiling treatment as well, pulls together that loft feel:
    http://www.concretenetwork.com/stain...s/ceiling.html
    Jun 2003
    sorry for the semi-hijack...but Northland Construction might have what I'm looking for - A industrial strength garage concrete coating. Any suggestions? I'm weary of the home depot stuff and there's online, but I'm looking locally for now.
    **SEQUOIA**
    there is some good info in this thread. i am looking to polish about 500 sqft - the problem is that there are cracks that have been filled, stains, etc so i wonder if you can paint the concrete and then polish it.
    the deciding factor for me is cost. I am trying to stick to a really small budget of $1k
    no, but with our furnace + electric fireplace we should be able to make it work
    Nov 2007
    I actually really like the look of the cracks in the floor AFTER they have been polished, it gives the room character imo
    Canyonero
    I'd never do it without in floor heating. Half my basement is currently concrete w/ an epoxy finish and it is cold as hell on bare feet.
    72 Virgins
    That is not going to happen.
    Only 15min from Aspen!
    Nothing interesting anymore
    Nope. It'll be chilly down there no matter how many heaters you put in. Concrete sucks the heat right out.
    Before I refinished mine, it was just carpet/flimsy underlay on concrete, it was FREEZING down there, even with the main floor heat cranked to 23*C. The temp. difference was 7-8*. When I ripped the carpet out, over the winter it was 10* diff, then after installing the subfloor (real subfloor, with 2x4's and foam insulation), it's now a 4*C difference.
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    This
    I have lived in a couple places with exposed concrete floors in the basement and without heat in the slab they are NOT comfortable. Okay, that isn't 100% true, in the summer when it is 30*C outside and you come inside and lay on the concrete floors because you are too hot, then they are comfortable, but for the rest of the year they suck.
  1. Anyone know where to get flat beading for hardwood floors?
    By UndrgroundRider in forum Home and Garden
    Latest Threads: 08-28-2010, 02:54 PM
  2. Replies: 4
    Latest Threads: 08-04-2009, 06:37 PM
  3. FS:4 polished zq8 rims 2 not polished 4 winter steelies
    By j_gor78 in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 06-30-2007, 10:53 AM
  4. has anyone done millwright journeyman?
    By brownchild in forum Campus Chat
    Latest Threads: 10-17-2005, 11:10 PM
  5. has anyone done this, or know how much to do this
    By ZED_24 in forum In Car Entertainment / Electronics
    Latest Threads: 04-13-2003, 09:24 PM
