Consumer Reports has given the Lexus GX460 a rare "Don't Buy" warning in yet another blow to Toyota's reputation.
The magazine says a problem that occurred during routine handling tests could lead the SUV to roll over in real world driving.
During a test of how the SUV handled unusual turns, the rear end slid until it was nearly sideways before a stability system kicked in.
Consumer Reports said in real world driving, such a scenario could cause a rollover accident.
As a result, the magazine has given the seven-seat SUV a "Don't Buy: Safety Risk" label until the problem is fixed.
Consumer Reports said the last vehicle to receive such a warning was the 2001 Mitsubishi Montero Limited.
"In a real world situation, by that time, the car can hit the curb or the side of the road and that's the situation where, in a vehicle like that, it could cause it to roll over," said Gabriel Shenhar, senior auto test engineer at Consumer Reports, who was one of four testers to experience the problem.
Blow to Toyota's reputation
Starting at about $52,000, the GX460 is a small-volume vehicle for Lexus, Toyota Motor Corp.'s luxury brand. But the warning represents yet another blow for Toyota's tarnished reputation for safety following recalls of millions of vehicles for faulty gas pedals. The GX460 is not covered by the pedal recalls.
Consumer Reports said the problem occurred during a handling test on its test track. During the test, the driver approaches a turn unusually fast, then releases the accelerator pedal to simulate a typical driver's response. This causes the rear of the vehicle to slide.
In normal cases, the vehicle's electronic stability control should quickly correct the loss of control. But Shenhar said in the case of the GX460, the stability control took too long to adjust, causing a risk of rolling over.
However, Consumer Reports said it is not aware of any reports of the vehicle rolling over. The magazine said it tested two separate vehicles, both of which experienced the problem, but neither rolled over.
Consumer Reports said it has notified Toyota and said the automaker is investigating the problem.
Read more:
http://www.cbc.ca/money/story/2010/0...#ixzz0l04CpUGl
