Removing in ground basketball pole - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: Removing in ground basketball pole
    Aug 2005
    Acura Integra
    Default Removing in ground basketball pole
    Hey guys,
    Does anyone have experience doing this? There is just a pole remaining at my parents house. There is cement in the pole and in the ground.
    The best idea would be to cut it off near the base and just bury whatever is below grade.
    How to do this safely? Anyone wanna come do it for some cash?
    Thanks
    Cowtown
    It has a shiny thingy on the front
    Take a hi-lift jack from one of your off roading buddies. Wrap a chain around the pole and start cranking. It'll come out.
    Aug 2005
    Acura Integra
    Thanks - that's actually what I will try.
    Nov 2004
    MB C63
    Let me know how that goes. I need to do the same haha.
    Jun 2007
    R50
    That truck idea is kinda extreme! I had to to this a couple years ago at my parent's place as well. All I did was to remove the sod from the top. Dig a couple more inches down. Grab a handheld grinder, cut around, put the sod back on, done!
    Mine was a clear cut. But if the cement inside your pole happens to be higher than your cut, you can wiggle and lift it, then break the cement with a hammer.
    Aug 2005
    Acura Integra
    I climbed up to the top stuck in a tape measure and the cement is about 3" from the top...
    I like the jack idea, otherwise it will be an angle grinder + sledgehammer.
    Unemployment Line
    Sierra, RDX
    I'll check in the morning if my Hi-Lift is where I left it, if it is you can borrow it.
    Sep 2005
    Acura TL, 2016 Yamaha FZ-07
    As soon as I saw the title of the page I thought of your parent's house where we use to shoot hoops and bam it's you that needs this gone.
    Aug 2005
    Acura Integra
    Yeah it's all rusted out now =(
    Bunch of Honda's
    My parents wanted theirs gone so we dug it all up only to realize that there was a at least a 36" round blob of concrete holding the pole in place....... not only did it weight a couple hundred pounds but it also took up alot of space. And since we have nothing to backfill it with we just cut the metal pole at the base and rolled it over in its origonal hole and burried it haha. Done.
    Apr 2010
    Use a grinder to cut a slot in the pole for the jack-all lift platform to fit into it. Make sure the jack-all is on a solid foundation, (I use a piece of header board, works great) and give' er. Even with a concrete footing it should come up. If you have to, use a 6' prybar and sledgehammer to wiggle the bar down around the concrete to loosen it a bit, should come up no problem. Done this a million times.
    2001 Chevy Silverado
    Umm, could you not just rent a jackhammer and jackhammer it out?
  1. Pole Vaulter and his Pole
    By treg50 in forum Misc. Gallery
    Latest Threads: 07-03-2008, 03:23 PM
  2. Where to put ground wires on DIY ground-wires?
    By GTS Jeff in forum Mechanical
    Latest Threads: 06-18-2004, 10:16 AM
  3. Rims - P/s - Pole
    By GT2NV in forum Performance Modifications
    Latest Threads: 04-28-2004, 01:39 PM
  4. pole vs. GTR R34
    By generation2 in forum Cars, Bikes, Machines
    Latest Threads: 06-18-2003, 09:17 PM
  5. Eagle Talon + Pole = No good!
    By Pete92SL in forum Street Encounters
    Latest Threads: 11-12-2002, 01:10 PM
