In the 94 Protege, the right front wheel vibrates when i brake...
At first it used to shake the steering which meant rotors.. so i replaced the rotors on both wheels
MUCH smoother, but now when i brake at high speeds there is still vibration... so if its not the rotors.. what could it be?
Car is fine and problem only exists when I am braking at high speeds... BUT -- its only when i push the brake pedal down 10%... When i want to brake smoothly and not hard the vibration is felt... but if i was to just brake hard and push the pedal down hard.. then it smooths out fine...
Because vibration is only when braking at high speeds + the first bit of braking.. would say its not the wheels..
Could the next option be un-even pads? (just using common sense here).. Or maybe the lug nuts aren't tight enough its causing the wheel to vibrate?
I'm not feeling it in the steering, just on the brake pedal and throughout the car... if i'm going 100+ and want to slow down gradually by pressing on the brakes it gets scary
Edit: I also changed the right wheel rotor with the left wheel rotor.. no difference problem still exists... My average joe guess is pads -- but i thought i'd ask for those who know something about cars, more than me
If it is pads.. how much do they cost?
