Lawnmower blade sharpening? - Beyond.ca - Car Forums
Results 1 to 16 of 16
Thread: Lawnmower blade sharpening?
    Apr 2007
    calgary/alberta
    Default Lawnmower blade sharpening?
    Anyone know where to take a mower blade to get sharpened?
    Mr. Madison, what you have just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
    Feb 2005
    Canada
    Man up, buy a Dremel, and sharpen it on the mower yourself
    Nov 2003
    I use a bench clamp, and a file to sharpen mine.
    Princess auto grinder ftw
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    I just sharpen mine by hand with a file. I put it down on a raised step, then put my foot on it to hold the blade in place, sharpen one side at a time. It's super easy and free
    Mar 2010
    Straight use your bench grinder!
    calgary ab
    4x4
    Oi vey... 1 or 2 bolts to remove. Hand filing/etc is bad ~35 degree angle on the bench grinder for ginsu cut, ~45 degree if you just want a hack that you wont have to redo for a year...
    Surely you must know a landscraper - any decent landscaper would likely do it for a beer - even decades later I can still do a blade in under a minute...
    missy
    A new universal one is $12.00ish (depending on mower)...
    CNC Guru*
    Instagram: goreski_rdd
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    Why is hand filing so bad? I took care to exactly match the angle that the blade was originally cut at, and to remove an equal amount of material from both sides.
    It seems to me that by using a bench grinder you make it easier to take more material off one side than the other and to put the blade out of balance.
    Mar 2010
    Hand filing takes more effort the switching over the on on a bench grinder. I think is funny how some people are afrade of noise and sparks.
    Mar 2010
    If you bring your blade to my place ill do it for free!
    calgary ab
    4x4
    Hand filing is bad - because you can very easy knock the blade out of balance by taking a bit too much off. Run it long enough and you're buying a new mower.
    When you're doing it with a bench grinder - you work in a smooth motion, and usually end up taking off very similar amounts. When I did it daily - it was only once in a blue moon (ie when I had a big rock ding to work out) that the blades needed any balancing when done. And each blade got checked right after coming off the grinder...
    Feb 2005
    Canada
    Buy a Dremel, use a grinding stone and sharpen it on the mower yourself Easy Peasy
    You'd have to be a clumsy idiot to unbalance the blade just by sharpening it.
    Jan 2006
    ^ If you're THAT worried about unbalancing it, spin it on a metal rod, if the same end keeps on "returning" to the bottom then that's your heavy end that you need to remove more metal off of.
    But as it was said before, its not hard. Aim for a 45 degree pitch. Too sharp of a cut will make it pit and dull easy.
    Oct 2006
    oooo
    or go to canadian tire and spend $16.00 for a new one
    2017 VW Jetta 1.4T (winter car)
    2010 F-350 Nortruck Tool Shed
    2007 BMW 5 (Wifey's)
    2004 Audi A4 1.8T 6spd Stage III w/ Meth
    1985 F-250 6.9L IDI w/ATS turbo
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    Who is afraid of noise and sparks?
    I don't own a bench grinder and I am not buying one just for the purpose of sharpening lawnmower blades. I think it is easier to take the right amount off by hand as compared to using a bench grinder, but I guess some people just can't hold their attention on one thing for more than 5 minutes. If you have a bench grinder then use it, but for most of us a hand file is good enough
    I always check my blades for balance when I finish sharpening them. When I first had to sharpen it I found the blade was already pretty badly out of balance, so when sharpening it I re-balanced the blade and I have never had an issue since. It is very easy to check if it is properly balanced.
  1. best place for skate sharpening
    By 5000Audi in forum Sports, Health & Fitness
    Latest Threads: 12-02-2008, 04:26 PM
  2. Skate Sharpening
    By jeremyn in forum Sports, Health & Fitness
    Latest Threads: 01-27-2008, 10:27 PM
  3. Skates sharpening
    By TomcoPDR in forum Health and Fitness
    Latest Threads: 12-30-2007, 01:43 PM
  4. Image sharpening
    By Aleks in forum Photoshop Gallery
    Latest Threads: 09-24-2007, 08:45 PM
  5. Sharpening skates
    By D'z Nutz in forum Sports, Health & Fitness
    Latest Threads: 03-11-2007, 07:19 PM
