D16Z6 Crank, 40k km. $60
P2P pistons in OEM Honda boxes, used but very minty. $40
PM6 pistons and rods, used but good condition. SOLD
D series water pump, BRAND NEW. $20
D16Z6 oil pump, basically brand new, very light use. SOLD
88-91 Civic Hatchback cargo cover $80 OBO
I will measure all the above items later tonight and make sure they are in spec. I have already dissassembled, measured, and reassembled the oil pump and it is very very nice inside. I would be using it if it would work with my pickup.
You can use the head, crank, PM6 pistons, rods, oil pump, and water pump to build a budget D16 with 10:1 compression and VTEC.
Cargo cover is MINT.
Measured the crank and it's pretty much brand new. At the very top end of the specs. Won't find a better crank anywhere else, I'll tell you that.
D16A6 Cam, good condition SOLD
OBDII Injectors SOLD
88-91 NGK plug wires $10
92-00 OEM plug wires $10
GReddy 2 1/4" filter $30
NEW D16A6 OEM timing belt (PM6) $40
Used D16Z6 timing belt, good condition (P28) $20
NEW D16 headgasket SOLD
D series exhaust flange $50
