Timing Chain rattle - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Timing Chain rattle
    Apr 2003
    '92 RPS13
    Default Timing Chain rattle
    So now that the car is up and running I've been trying to fine tune all the little bugs. Well I fired it up on Sunday and went to back out of the garage. Once I got out into the alley the timing chain started rattling like crazy, so I gave it a couple revs and the rattling went away for the time being. Moved it back into the garage as I wasn't sure if it was safe to be driving, and the sound had come back. Couple more revs and it went away.
    The motor is an Sr20det S14 Kouki Blacktop with maybe 50,000 kms give or take.
    Sounds like the chain is hitting the Chain Guide, but I wanted to seek advice on if the chain or maybe just the tensioner needs replacing, thanks guys!
    Dec 2007
    Airdrie Alberta
    tensioner
    you revving it increased oil pressure and made it move
    Jan 2009
    South of Glenmore Trail :P
    Depends on the day
    Originally posted by sr20s14zenki
    tensioner
    Get it fixed asap before you screw the motor.
    Apr 2003
    '92 RPS13
    Thanks guys, how long would it take to replace the tensioner?Should I do the full chain replacement while I'm in there?
    Dec 2007
    Airdrie Alberta
    haha the tensioner is this
    change that before you do anything else, because the rest involves the front cover off, which effectively means head comes off. The tensioner is changed outside the block, literally takes 10 minutes
    Apr 2003
    '92 RPS13
    Thanks Zenki! I'll order one and get that put in asap
    no I know that, but I was thinking of just going with this:
    http://www.frsport.com/OE-Complete-T...ET_p_1351.html
    Replace everything while I'm in there.
    May 2003
    2002 Lexus GS430
    the timing chain tensioner takes minutes to replace. if you really want to change all the parts, it'll take you a good 5-6hrs if you know what your doing.
    just buy OEM nissan tensioner, not that stuff from FRsport as they arent OEM nissan.
    Oliver
    Jun 2004
    Calgar3h
    S14|TB1
    ^those timing guides look exactly like the OEM ones i bought from infiniti (brasso ordered) back in the day
    when i did mine, because i had the whole front timing cover off, i actually got a whole front end seal kit (ask Mike at Brasso if he still works there, he'll know) and replaced all of the seals while i was in there, why the hell not right?.
    if your timing guides are the same OEMs from factory, youll be happy to see in the picture that the guides (infiniti G20 OEM stuff iirc) are backed by a metal base, i remember taking mine out and seeing both were made of all plastic, putting the metal backed ones give a little more piece of mind but i doubt i'll own my SR to the length that they need replacing again.
    Apr 2003
    '92 RPS13
  1. Timing chain rattle or rod knock?
    By 240SX92 in forum Nissan 240sx / Silvia Owners
    Latest Threads: 09-07-2010, 05:34 PM
  2. FS- Timing chain cover and kit - Toyota 22R
    By frozenrice in forum Automotive Parts
    Latest Threads: 12-14-2007, 05:50 PM
  3. Timing chain guide
    By duffspec in forum Nissan 240sx / Silvia Owners
    Latest Threads: 10-22-2005, 08:36 PM
  4. sr20det timing chain marks
    By n1zm0 in forum Mechanical
    Latest Threads: 07-14-2005, 09:26 PM
  5. 98 malibu 2.4 timing chain
    By amcdan in forum Mechanical
    Latest Threads: 01-04-2004, 05:04 PM
