Hey guys,
I have a Brand New still in Box 10" powered subwoofer by Klipsch from their Reference line.
Specs:
FREQUENCY RESPONSE 28-120Hz +/-3dB
AMPLIFIER POWER FTC Rated Power: 260 watts continuous @ <2% THD / Dynamic Power*: 575 watts
MAXIMUM ACOUSTIC OUTPUT 112dB @ 30Hz 1/8 space, 1m
DRIVE COMPONENTS 10" (25.4cm) Cerametallic™ cone, front-firing woofer
AMPLIFIER BASH® digital hybrid
ENCLOSURE TYPE Bass-reflex via front-firing CornerPort™
INPUTS L/R Line-level RCA jacks, L/R High-level speaker binding posts
OUTPUTS None
HEIGHT 17.8" (45.2cm)
WIDTH 12.5" (31.8cm)
DEPTH 19" (48.3cm)
WEIGHT 39lbs (17.7kg)
FEATURES DCS control and feature set w/ 3 system presets
FINISHES Black Ash woodgrain or Silver matte vinyl
VOLTAGE 110/120 VAC 60Hz
EXPORT VOLTAGE 220 VAC 50/60Hz
http://www.klipsch.com/na-en/products/rw-10d-overview/
All photos is essentially the box. I bought this awhile back and haven't had a chance to use it. I had a smaller room in mind for my HT build and have moved and have a much much larger room. Lots of great reviews for this sub and it's equipped nicely with a digial lcd display and a IR sensor for remotes allowing quick on the fly adjustments.
For serious buyers, if you would like to demo the woofer give me a call or a text and we can arrange a meeting. Please bring your own connection cable required for your player to output as well as your own subwoofer cable as I'm not sure if there is one inside the box. For best results, I suggest bringing an Ipod with your most familiar songs in the highest quality(320kbps-lossless wav).
The receiver it will be hooked up to is a Pioneer VSX9130THX
I'm located in Calgary upper NW
Feel free to ask questions.
Richard
Email : [email protected]
C.Phone : 403-618-9281
$400.00
