Blow in Attic Insulation Providers - Beyond.ca - Car Forums
Results 1 to 20 of 27
Thread: Blow in Attic Insulation Providers
    Jul 2006
    FJR1300/2018 Giant Trance 3
    Default Blow in Attic Insulation Providers
    I was up in the attic last night installing a ceiling fan in my daughters room, and it appears they skimped a bit on the the blown in cellulose. I have about 6-8 inches of the stuff up there, and I'm thinking I'd like about 15-16. So, anyone know of a reputable installer?
    Thanks in advance guys.
    Jul 2007
    Blue boy
    DIY, it's very easy. You can rent the machine from Home Depot, have someone dump the insulation in the machine and you spray as much as you want
    Dec 2006
    SRT Charger
    x2 My parents just did their garage last summer this way and are in their 60's . Way cheaper than paying somebody to do it.
    Jul 2006
    I got a couple of quotes back already. They're quoting around $600 for time and materials. That's pretty reasonable for a job that I don't want to do.
    Jul 2007
    Blue boy
    If you want, I can ask my friend if hell do it
    Apr 2004
    Can you let me know where you got the quote. Would save me some time.
    Jul 2006
    Affordable Insulation has called me back so far.
    http://www.homeinsulators.com/
    He's quoted $671 for approx 913sq feet. They use fibreglass blow in, and I'm looking for cellulose. Everything I've read shows that cellulose is a superior product. But he can come tomorrow if I book him today.
    *This is not a recommendation*
    Also called:
    Zero Draft 403-651-8822
    http://zerodraftcalgary.com/
    They took my info, and will have a quote person call me this afternoon.
    Celltech 403-243-4614
    No website.. seems to be a small outfit.
    I got these names from Can-Cell Industries.
    May 2003
    -10 F150 Lariat, -10 Fusion SEL awd
    just an FYI, I had a real rough time with zero draft.. they had a real hard time returning calls, and actually showing up...
    C.J.
    1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
    Jul 2006
    Black,
    They're coming by tomorrow to give me a quote on cellulose blow in. Didn't take long for them to call me back get a quote for me.
    TRD Pro
    Thanks for posting the info...
    I contacted Home insulators for a dril, blow and patch estimate. (Im in a 1910 build home, with likely no insulation in the walls!)
    Jul 2006
    I ended up going with the Zero Draft quote. They're coming next Thursday to add R30 of cellulose. The quote guy was pretty thorough while he was up there. I have a fair amount of frost on the inside of the roof, and he thought at first it was because I had a huge air leak into the attic, but after poking around and finding (and fixing) one little tear in the vapour barrier, he figures it's because the insulation stops were compressed on about half of the rafters, and the trapdoor wasn't properly sealed. This goes hand in hand with my super high humidity in the house (75% RH) that I had and my wife running the humidifier in my daughters room till water was running down the walls. Attic access in that room.
    So, they're going to add in 28 rigid foam insulation stops, use a 2 part foam on my attic hatch, and add in R30 to bring it up to R50. Final cost is quoted at about $1000 tax in. It would have been $100 less if I went fiber glass, but I've read enough online to be convinced that cellulose is a superior product. This quote was in line with what my dad paid north of edmonton for his attic to be done with cellulose plus the calgary tax.
    Jul 2006
    FYi, I went with Zero draft. The guys were fast, professional, and kept me informed on what they were doing through the whole process. They put in 38 bags of insulation up there to bring it up to an R50. Total price was $1032 for 913 sq feet of attic.
    Sep 2012
    Bump from the dead!
    So you guys that did insulation top-ups, did you find it made a difference in comfort and/or energy usage?
    Sep 2012
    Had my attic topped up to R50. Made a huge difference. Not sure if the furnace is going to run less so much that it'll impact my bill, but it's way warmer upstairs.
    Also sealed the attic hatch by spray foaming the space between the trim and the hatch sides, and put weatherstripping around the trim where the hatch meets. There was definitely a moisture problem there as there was ice all around the hatch sides. Checked this morning and there's just a tiny bit left. I'm going to put some VB and more insulation around the sides to see if that helps.
    Also spray foamed around the furnace room door casing, wow that really cut down on the noise.
    Oct 2003
    just had mine done, went with Ideal Insulation. Added air chutes and topped up to r50. Luckily had it done right before the current cold snap. I used an IR thermometer to measure ceiling temps before and after, with no changes to the thermostat set to 21C. Before top up, was getting 17C-18C, day after 21C. Measured same time of day, outside weather was about the same on the 2 days. Definitely worth it for me.
    heloc that shit
    Calgary, AB.
    210000 km oldie
    I am going to get ours done I think. Will try a couple places.
    Oct 2003
    ute
    Bump...is this worth a retrofit?
    I have to re-insulate the section above my bathroom reno upstairs (I should have done it in the summer). But they would have to pull out all of the old fibreglass and put cellulose in, I think?
    Jul 2013
    Calgary / Alberta
    I thought you had garbage bags full of cellulose up there. Why not just rip em open and spread it around the bathroom ceiling. Or place any batts you have up there between the rafters/against the vapour barrier. Wish you woulda mentioned it, as I would have even done it while I was up there.
    Oct 2003
    ute
    I thin kit's the pink fibreglass?
    And I'm feeling a bit lazy to get up there now...lol.
    Thanks gain for the work, that was a lifesaver.
    Only 15min from Aspen!
    Nothing interesting anymore
    Yes. We had our 50's bungelow done in the spring. We definitely noticed a difference in the summer heat. The attic didn't heat soak the house like it had in the past.
    In the winter, honestly didn't notice a big difference. So what I did was setup my furnace to run the lowest speed fan 24/7 (although hooked up to an easy to access switch, which I turn off when it gets above 0*C), and when the furnace kicks in, it runs at med-high speed.
    This has made more difference (in winter) than anything else I've done in the past decade to our house. No more cold spots, no more drafts, and it only costs about $20 a month more in electricity.
  1. Replies: 17
    Latest Threads: 02-07-2012, 03:43 PM
  2. Replies: 13
    Latest Threads: 09-22-2011, 12:42 AM
  3. Airleak and cold in attic
    By Gorilla in forum Home and Garden
    Latest Threads: 10-27-2010, 07:24 AM
  4. attic online shop 40% off
    By aypi in forum General
    Latest Threads: 09-25-2009, 10:54 PM
  5. Blow, blow
    By adidas in forum Misc. Gallery
    Latest Threads: 01-25-2009, 01:31 PM
