Remote start and FOB key? Disable? - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Remote start and FOB key? Disable?
    Jan 2007
    CALGARY
    Default Remote start and FOB key? Disable?
    A friend of mine just bought a 2010 Dodge Ram which has a FOB key. I've got the truck in the garage ready to install a compustar but i can't seem to get any real anwsers if i can do it. Called a few install shops and 2 said they can't and 1 said they could. Help!!!
    Will the truck run without the FOB key?
    '16 F-150 Lariat 5.0
    by FOB key you mean immobilizer... you will need a bypass module.
    Check out the12volt forums for more information. Cruise threads in the automotive electronics forum here on beyond for details on which shops are recommended.
    Jan 2007
    CALGARY
    Aug 2003
    Cochrane, AB
    I would say its totally possible but you would need a programmed key for the bypass. Doesn't dodge have a factory solution for remote start? I would seriously consider that as an option. The price of buying the unit after the fact might be very close to an aftermarket solution. Without the need for a bypass and having two fobs.
    Tip keys are super easy.. it's like a 8 wire install with the Idatalink CA... I love doing those cars..
    Power, Ground, Ignition, Can HIGH, Can Low Park light flash, siren, and Rap shut down..
    99 ITR
    Ya any futureshop or bestbuy can sell you the security bypass module. If you are doing a compustar you can use an idata blade it is the simplest for installation. http://www.idatalink.com/search/index/model/6524
    Jan 2007
    CALGARY
    I have never heard of this software.
    What is the software for? the compustar or the truck?
    Either way im passing on this install.
    Sometimes you have to take a chance, whether that be on someone, or something!
    it's for the idata link module.. that is required to bypass the transponder and to communicate with the car.. Seriously if you know what your doing, the 2008 to 2010 dodges are the easiest cars you can do.. No more resistors, more MUX wires, and no more isolating park lights..
    1 to 2 hour max... (2 hours being if you have never done one before)
    Aug 2002
    You Crazy
    you have PM
    Jan 2007
    CALGARY
    Easy was my GM with VAT system!!
    I passed this one up but did do some digging into the dash and what not reading with a volt meter but that didn't do much if anything. Customer wants push button with no rfid.
  1. Command Start key Fob
    By hipeagle in forum In Car Entertainment / Electronics
    Latest Threads: 11-05-2009, 09:55 PM
  2. model CS- 555 key fob
    By click-rempel in forum In Car Entertainment / Electronics
    Latest Threads: 11-30-2006, 10:42 AM
  3. GM's new key fob can check fuel level, tire pressures
    By benyl in forum Automotive News
    Latest Threads: 11-19-2006, 10:23 PM
  4. Key Fob Programming
    By larencel in forum General Car/Bike Talk
    Latest Threads: 11-25-2005, 05:49 PM
  5. Who can reprogram a key fob
    By nine8civicSi in forum In Car Entertainment / Electronics
    Latest Threads: 02-15-2004, 12:10 PM
