Rattling noise at certain RPM - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Rattling noise at certain RPM
    Default Rattling noise at certain RPM
    Hey all,
    I was recently given a '85 Volvo360 GL and have noticed a rattling noise when the engine is between 1800-2100 RPM. Or maybe the rattling comes from 1800 onwards but after 2100 the engine blocks the rattling noise, I dunno .
    I've checked the basics, has anybody else ever had this problem or have a solution?
    Thanks in advance. If you need specs let me know.
    Sep 2003
    Calgary Alberta
    ...BNT0B0X...
    Describe if you can...Where is the rattling coming from??...and is it constant with the RPM or comes and goes...And what have you checked??
    Vancouver
    1993 Nissan 240sx
    yeah there are a lot of things that could cause this rattling
    motor mounts
    driveshaft
    wheel balance
    etc
    see if you can figure out what's causing it
    good luck
    It is constant with the RPM, once it hits approx 1800 it starts. It sounds like when you hit two marbles together and i'd say about 5 times a seconds. Once the engine hits about 2100 it either stops, or the engine noise is too high and muffles it.
    I've checked stuff like the oil, petrol type, and a friend checked the filters and he said they're OK
    C-Spot
    will molest you in 11 sec
    "It sounds like when you hit two marbles together and i'd say about 5 times a seconds." If what your describing is pinging (AKA premature detonation) then it may be an easy fix. It could just be carbon build up in the cylinder. Is your volvo a turbo? Cuz most cars with turbos are biased to premium gas. Also if you car doesn't have many km's on it then it probably isn't build up and is sumthing else, like valve-piston contact, which is VERY bad!!! best thing to do is fill up with premium and run a good fuel system cleaner and injector cleaner setup. If that doesn't work take it into a shop Immedieatley before sumthin breaks.
    oreo cookie
    a wrx.
    ^^^ a better way to describe detonation rather than "hitting 2 marbles together" is "rattling an pop can with BBs inside it"
    T2S
    pedals
    a problem i had with my car was that it was the heat sheild on the exhaust and firewall were loose and it would rattle like that at certain RPM's. Check that out.
    '07 Ranger FX4 Level II
    check all your exaust mounts (espically the ones that are metal on metal)... when i rebuilt rice cakes i forgot to hook up one of the exaust brakets that goes on the motor and it would rattle pretty bad...
    Originally posted by rage2
    Ok all, thanks for the responses
    I've researched carbon build symptoms and I think this could be the problem, will tell if it fixes it.
  1. Is it legal to keep certain items in a car
    By Redlyne_mr2 in forum General Car/Bike Talk
    Latest Threads: 07-18-2003, 11:58 AM
  2. Replies: 12
    Latest Threads: 06-30-2003, 01:26 PM
  3. Certain people....
    By CeeLo in forum General
    Latest Threads: 06-22-2003, 09:56 PM
  4. Suspension Noise
    By RiceCake in forum Mechanical
    Latest Threads: 10-05-2002, 03:42 AM
  5. Rear Suspension, funny noise
    By Ferio_vti in forum Mechanical
    Latest Threads: 09-30-2002, 10:41 PM
