We built with Cardel and have been in our home for 9 months and everything has been a problem....some major problems as well.
1. Gas leak in our fireplace as the fitting was loose. ATCO Gas discovered the leak after we called them in when we had a problem with the pilot.
2. Faulty damper on furnace -- no heat for six weeks because they said there was nothing wrong with it and didn't want to address it.
3. Humidifier needs to be replaced.
4. Hole in roof caused leak to bedroom -- damaging the walls, baseboard, and doorframe....took way too many visits to diagnose, fix and then repair.
5. Linoleum has lifted from under the hardwood twice in the same area.
6. Plumbing problems where they had to cut three holes in our ceiling to find the problem. Loud plumbing when water runs through sink still an isse.
7. Severely cracked garage pad due to rebar from driveway work - they probably won't fix it because the crack isn't big enough.
8. Leaky taps.
9. Windows have had to be replaced.
10. Fireplace glass had to be replaced.
11. Hot water tank fan required replacement.
12. OTR Microwave had a faulty magnatron.
13. Paint cracking/peeling.
14. Floor ducts not secured -- I could see my basement clearly through our floor vent on the main floor.
15. Plumbing and vents are touching one another in several places thus causing loud clanking that reverberates through the pipes and vents
16. Tyvek home wrap was still visible at the roof line
17. Stucco crew just showed up with no notice and started working at 8am on Good Friday --- started attaching their scaffolding to the home, woke us up. Cardel didn't advise us at all about the work starting on the long weekend. Not only that, the stucco guys were complete ass holes that didn't know what they were doing.
18. Incorrect wall switch for fireplace, creating resistancde.
19. SHITTY customer service --- won't even inspect the home to be proactive in addressing any further deficiencies -- I've addressed it with the VP and President now and they just don't care once they have your money!
Those are just the 'bigger' issues, we've overlooked alot of the minor items to ensure the big stuff gets fixed.
DO NOT BUY CARDEL!!! Poor communication, poor trades, poor customer service, and shady sales staff. The VP blames his trades but in the end, the purchase agreement says Cardel Home. They are responsible for selecting their tradespeople and therefore, they need to take responsibility for their homes.
Plus, I know for a fact that they have hired staff that have been fired from other companies so they basically hire shitty staff....says something about quality!!!
