Just an article from Yahoo.
Winter driving tips - warming up the car
- Jeff Voth, Yahoo! Canada Autos
Those of us who live in a four-season climate are used to the idea of allowing our vehicles to warm up on a cold winter's day. But with the technology in today's automobiles, is this still something we should be doing? The simple answer is no. For the most part, letting your vehicle idle for long periods of time in the cold is not only bad for the environment, but can cause serious damage to your engine and emission system.
In the past, most vehicles employed a carburetor to deliver fuel to the engine. Today, almost all cars, trucks and SUVs on the road use some form of electronic fuel injection. In a cold engine, the computer management system tells the fuel injectors to stay open longer allowing more fuel to flow into the engine in part to keep the engine running cool. Trying to warm up the engine at slightly above idle speed is actually doing the reverse and inviting additional problems.
Cold engines produce a much higher level of unburned hydrocarbons as fuel needs heat to burn efficiently. Even the best catalytic converter is unable to process 100 per cent while running at maximum temperature, so allowing the engine to idle for extended periods of time can start to clog the system.
In addition, spark plugs may also become plugged or dirty due to inefficient fuel burning. Older vehicles required regular maintenance, calling for spark plugs to be changed every 30,000 km. Today, almost all engines employ an electronic ignition system that requires spark plugs to be changed at intervals in the range of 100,000 km. An engine at idle for extensive periods of time could dramatically shorten the life of your plugs, causing you to spend hard-earned money on unnecessary service and maintenance.
A better approach is to start your vehicle and let it run for up to one minute before driving away. This will allow fluids to begin flowing through the engine and then warm up to efficient temperatures under normal driving conditions.
Should the temperature outside dip below freezing, allow a maximum of four to five minutes of idle time before driving away. This should be just enough time to clean off any snow or ice that may have accumulated on the windows. While you may not be warm as toast on the way into work or school, you will benefit by saving money at the pump and garage and by driving a vehicle that runs cleaner and more efficient for many years to come.
http://ca.autos.yahoo.com/p/2052/winter-driving-tipswarming-up-the-car
