1990 Nissan 300ZX Twin Turbo - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 43
Thread: 1990 Nissan 300ZX Twin Turbo
    Jan 2003
    Arizona
    F355 GTB-Fiero GT-Civic Si-Champ Car-300ZX
    Default 1990 Nissan 300ZX Twin Turbo
    Engine:
    Zemulator engine management
    Zeitronix Wide Band O2 setup
    RC Engineering 720cc injectors
    Greddy SMICs
    Port matched intake manifold
    Knife-edged TB's
    Koyo aluminum radiator
    Clutch fan replaced with 16" electric fan (controlled by thermostat)
    JWT intake
    EGR delete
    Water lines under plenum delete
    Apexi AVC-R Electronic Boost Controller set at 13psi
    Apexi Turbo Timer
    Full turbo-back custom exhaust including:
    Greg Dupree Split Flange Down Pipes
    2.5" Y-pipe (no cats) to single 4" with Magnaflow muffler
    Exterior:
    99 JDM front fascia with licsense plate bracket removed
    Glare guards removed from fog lights
    4500K HID low beams
    All badging removed
    Interior:
    Autopower Race rollbar
    G-Force 5-point camlock harness
    FD3S RX-7 black leather seats
    Brushed aluminum guage rings
    Removed ~70lbs of weight from the car
    Wheels:
    Street-
    F-Blitz Type-03 18X9 with 275/35/18
    R-Blitz Type-03 18X10 with 295/35/18
    Track-
    F-Enkei RPF1 17X8 with 255/40/17 Victoracer V700
    R-Enkei RPF1 17X9 with 275/40/17 Victoracer V700
    Stock rear 16X8.5 wheels all around with Victoracer V700 245/45/16 (will be replaced with 265s)
    Brakes:
    F-RMS Wilwood 12.5" 6-piston front brakes with SS lines
    R-Stock
    Suspension:
    worn out stock springs with factory adjustable shocks
    Noltec adjustable front upper control arms
    SPL adj front tension rods
    Kazama adjustable rear upper control arms
    Soon to be added:
    custom ITB intake manifold
    Wilwood 4-piston 12.2" 2-piece rotors (rear)
    SPL adj front upper arms
    SPL adj front lower arms
    SPL adj rear lower arms
    SPL adj rear traction rods
    AMZ HICAS eliminator
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Pics taken 12/25/04
    New Wilwood brakes installed. 12.5" X 1.31" curved vane 2-piece rotors with billet aluminum 6-piston calipers. I went with 12.5" rotors because they fit inside stock wheels.
    Jan 2003
    Arizona
    Pics Taken 12/25/04
    RX-7 seat with G-Force 5-point camlock harness. The RX-7 seat has a lower base, larger sidebolsters, and weighs ~half as much as the stock Z seat.
    The harness holds me tightly so I can use my arms and legs to drive the car rather than hold myself in it.
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Pics taken 01/11/05
    Installed SPL adjustable tension rods. Now I have full control of caster and the mushy rubber bushings are replaced with pillow ball mounts.
    I replaced the stock upper control arms front and rear with adjustable units.
    Also washed the insides of the wheels.
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
    Jan 2003
    Arizona
  1. Z_Fan's Red Nissan Twin-Turbo 300ZX @ the Track
    By Fluidic in forum Cars, Bikes, Machines
    Latest Threads: 10-27-2003, 01:02 PM
  2. feeler: 1990 300zx Twin turbo
    By Trilabs in forum Automotive Parts
    Latest Threads: 08-05-2003, 08:02 PM
  3. WTB: Exhaust for a 300ZX twin-turbo
    By mrmattyk in forum Performance Modifications
    Latest Threads: 01-09-2003, 10:00 PM
