so im no mechanic wich is why Ive come here for some help with what could be wrong with my truck.
heres whats happened so far
after it was around minus 30 over night i had not plugged in my truck, It usually starts on cold days if do this but this time It started for about 30 seconds and then died...tried it again and it did the same thing.. but this time the battery was completely dead after running.
Later on in the day i boosted the truck and it would start and would struggle to run for more then a few seconds. eventually it would not even run anymore.
I have since charged the battery and it has maintained a charge for the last few days....my thoughts were that I had a frozen gas line because my tank was a bit low... so i put in some gas line antifreeze and topped the tank up with 40liters of gas and have since kept trying it everyday thinking maybe when the weather warms up it will start
No dice, The fuel pump turns on i can hear it.... the truck turns over....battery seems fine, Ive tried it with a boost and it does the same thing as without turns over but doesnt start.
I feel like its fuel related but i need help diagnosing my problem... could it still be frozen up even after a fairly warm yet freezing day...should i tow it inside? is there a better product to use to try and get it to start....any help would be awesome
