Hi guys,
Is it required to use PT lumber for the bottom plate since it is touching concrete?
Thanks.
Hi guys,
Thanks.
I'm no carpenter so I guess my opinion isn't really valid. But my thought would be that as long as you don't have moisture issues in your basement that PT should not be required.
if you dont use pressure treated you are suppoesed to use some kinf od a vapor barrier / seal to stop the moisture from coming up through the concrete and rotting the wood out over time..
C.J.
1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
Even if it isn't a requirement it is still a good idea to do regardless.
Depending on what chemicals were used, pressure treated wood is not advised to be used for interior use. High moisture content causes shrinkage, as well, the sawdust from cutting is toxic. There are some uses..but best to avoid it. Just use proper vapour barriers.Originally posted by sputnik
http://www.uri.edu/ce/factsheets/sheets/chemwood.html
