Hi,
I have a new remote and need to know how to program it...
its a j5f-tx2000
thanks in advance!
Hi,
its a j5f-tx2000
thanks in advance!
Get under the dash to the unit.
You will see 8 or 9 dip switches on the unit with an LED beside them.
Turn switch 1 and 8 on.
Press and release the brake. (LED will flash)
Press and hold start button on remote. (LED will flash and parklights will flash once.
Turn switch 1 and 8 to off.
Press and release the brake (LED will flash once)
Try your new remote!
What a coincidence, I have the exact same system and was googling to find the instructions.
I also have a second remote but is branded command start, any idea if this will work with the Astrostart system?
no. systems are meant to work with a certain brain with a certain antenna with a certain remote. you cant just use any ol' random remote and code it to your system.Originally posted by variance
