1991 dodge stealth only starts when... - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: 1991 dodge stealth only starts when...
    Aug 2009
    AB
    Default 1991 dodge stealth only starts when...
    My 1991 dodge stealth has recently had some trouble starting.. I can only get it to start if i hit the little flap to move your steering wheel up and down and push the steering column all the way down. Sometimes I have to play with it for quite a while before it will go.
    Anybody have any idea what to look for?
    Sep 2008
    Turbo stuff
    Continuity in ignition wires.
    Sounds like there's a sketchy connection that only completes the circuit when you jiggle it just right.
    Sep 2007
    A vehicle or two
    Yeah - clearly it is the ignition wiring.
    Consider yourself very lucky that you found the likely problem so soon.... intermittent faults are the absolute worst things ever.
    Jun 2007
    Medicine Hat
    MY97 WRX
    Take off the steering wheel surround ensure all plugs are 100% plugged in correctly. Seems like something is loose.
    Jun 2006
    Horse
    could also be a broken wire in the harness that runs up the steering column
    Originally posted by rage2
    Ya, I built some crazy ass shit with Lego as a kid. I had a thing for AMC Eagle AWD's as a kid for some bizarre reason, so I spent a lot of time going to the library and reading up on how AWD works in that car. I even hitchhiked to the library once cuz my parents were too lazy to drive me haha. Ya, I'm a nerd.
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    Problems like this are almost always a broken wire.
    Copper by nature hardens every time it is flexed after a while it becomes very brittle and eventually snaps.
    there should be a connector right at the ignition switch, and if not there should be some soldered wire joints. take a multi and place one probe on the connector or solder mound, then find the next connector further down the harness. it should be somewhere under the dash, or connecting directly into a fuse/powe junction box.
    if at first they have continuity, then wiggle the wires until you find the one which is broken.
    you wont need to replace the harness if it broken. just a little solder and some shrink wrapping will take care of the issue. I don't recommend crimp connectors here as the current passing through these wires can sometimes reach 80amps, that is far to much for crimp connectors
    Aug 2009
    AB
    sorry to bump an old thread but i opened up the steering column and it was a broken wire, easy fix! thanks guys!
  1. FS: 1991 Dodge Stealth RT Turbo / 3000gt
    By v8killa in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 09-08-2010, 11:40 PM
  2. Integra only starts some times.
    By cjay^ in forum Mechanical
    Latest Threads: 01-09-2010, 12:58 AM
  3. FS: 1991 dodge stealth ES
    By takeshi in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 05-15-2007, 05:02 PM
  4. 1995 Dodge Stealth R/T Twin Turbo
    By HillBilly in forum Dodge
    Latest Threads: 04-04-2005, 04:01 PM
  5. FS: 1991 dodge stealth-parting out (in St. Louis)
    By cindy lou in forum Automotive Parts
    Latest Threads: 03-19-2004, 10:09 AM
