Outdoor Kitchens/ My wood fired oven build - Beyond.ca - Car Forums
Results 1 to 20 of 33
Thread: Outdoor Kitchens/ My wood fired oven build
    Jun 2003
    Canada
    GMC Sierra
    Default Outdoor Kitchens/ My wood fired oven build
    My company builds outdoor kitchens and living spaces. I've been pretty fortunate to work on some pretty fun projects, like built in bbq's:
    And outdoor fireplaces and patios (built the wood box out of firebrick in herringbone pattern):
    My current project on the go is an Italian Style wood fired brick pizza oven. I downloaded the free plans from www.fornobravo.com
    There is a forums there and pretty much all the information needed for people to build their own.
    Information I have gathered about the ovens, temps can reach 800+ degrees, cooking temperatures can be maintained for 12+ hrs (you can bake bread the morning after a fire) and cook a pizza in two minutes.
    My motivation:
    Jun 2003
    Canada
    GMC Sierra
    On to the build, here is the concept for the stand for the oven. A very basic drawing (still learning sketchup) with wood storage under the oven:
    And here is the space I am working with, kind of small but just means we will have to have to be efficient with the footprint of the oven:
    Notice the orange tarps overhead (still raining lots here), they will be giving most of my photos a lovely orange hue
    Jun 2003
    Canada
    GMC Sierra
    Laid out the block stand, drilled holes into the pad and doweled vertical rebars into the pad to help tie the pours together:
    After the block stand is at height I core filled all of the blocks with concrete. Doing this in two pours helps give me something solid to attach my countertop forms to as well as makes bending the rebar over into the slab much easier.
    At this point, the forming is pretty much done except for vertical support under the overhangs.
    Sep 2010
    fucking awesome! i plan to do this same thing once I can get enough money to buy an actual house instead of a condo. i hope you post up some pics of all the awesome stuff you make this summer.
    oh, and that looks like a super cool job, too!
    Sep 2007
    A vehicle or two
    Totally ballin. That'll be insane.
    Jun 2003
    Canada
    GMC Sierra
    4" concrete countertops:
    The concrete cured overnight then stripped the sides of the forms off and wet sanded to give the slab a little bit of texture:
    before
    after
    Now the slab needs about a week curing before the vertical supports are removed
    Jun 2003
    Canada
    GMC Sierra
    Thanks guys!
    Stonework time, we faced the block walls with 5" thick natural sandstone, hand chiseling each piece and even rounding the sandstone to the same arc as the countertops:
    I found a nice big rock to serve as a one piece header over the wood box:
    Fucking awesome, keep the pics coming.
    Jun 2003
    Canada
    GMC Sierra
    Time to layout the oven, I am using standard size refractory fire brick (can be found at IXL) and the floor is sitting on 2" of fireproof insulation board. As per the plans, I am using a herringbone pattern for the oven floor so as to reduce the hard edges that might snag a pizza crust:
    Jun 2003
    Canada
    GMC Sierra
    After the oven floor is done, I built the oven entry opening:
    And then the dome starts,
    Jun 2003
    Canada
    GMC Sierra
    More of the dome under construction:
    Used styrofoam forms once the oven was near the top, at this point it gets tricky as the dome radius gets tighter, the compound cuts get more extreme. I widened up the joints and used a more coarse mortar to speed things up a bit. After the oven is used a few times the brickwork will be blackened in soot anyways:
    Jun 2003
    Canada
    GMC Sierra
    The dome is complete! It was a pretty good feeling, pulled the forms out immediately so the inside could be cleaned up from the mortar:
    Jun 2003
    Canada
    GMC Sierra
    Now it needs to sit and cure for a few days, then it needs to be cured further with fires, each one increasing in temperature. Still quite a few steps to go, I have to build the chimney out front of the oven, the dome needs to be insulated, then it gets a scratch coat layer, then it will be clad in tile. Stay tuned for more progress
    Nothing Good.
    That is brilliant work man. Wood fired everything is going to be killer. So your going to open a late night, after the bar, "beyond wood fired pizza stand" right?
    A Ferrari is a high maintenance chick, you spend money regardless of what you do with her. You can baby the C63, or slap on all seasons, and you won't be spending anything but yearly maintenance. Of course that's like dating a stripper and refusing to fuck her, which would make you gay.
    Originally posted by Rage2
    Feb 2003
    Wow, very cool build. I never realized how much work goes into one of these.
    2016 Tesla Model X
    2018 Lincoln Navigator
    2016 Porsche GT3 RS
    Oct 2009
    Sweet progress pics, SX. Looking forward to the finished product! A lot of hours in that project. Very nice work.
    Sure..if you wanna fly out to the Island after last call!
    Sep 2010
    i'd volunteer to help out with the pies. here's a Nick and Vito's clone from a couple of weeks ago:
    click for larger version
    Jun 2003
    Canada
    GMC Sierra
    haha good idea, i bet a wood fired pizza joint would do pretty well in Calgary
    Yup pretty time consuming, took 4 days from the floor of the oven to finishing the dome
    Thanks Dave, I might need some tiling tips for over the dome
    Dam those pies look good
    6.7 CUMMINS, E50 AMG
    wow man you have some skill! I wish i could work with stone and brick like that!
    awesome job
    Feb 2003
    Calgary. AB
    Nice work! That's awesome!
  1. Papandreou fired! Berlusconi fired? Merkel "decade"
    By ZenOps in forum Society / Law / Current Events / Politics
    Latest Threads: 11-07-2011, 08:09 AM
  2. Kitchens
    By 89coupe in forum Home and Garden
    Latest Threads: 08-04-2011, 02:20 PM
  3. HELP! Kitchens Hot Water Off
    By 4lti in forum Home and Garden
    Latest Threads: 01-11-2011, 03:00 PM
  4. FS: Children's Outdoor Playset Swingset PT WOOD $100
    By project240 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-09-2010, 08:54 PM
  5. WTB / LF: Someone to Build an Outdoor storage shed
    By jmc in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-20-2007, 08:49 PM
